yes they are compatibale
Hello
Is anyone able to confirm or deny whether the ring gear on an auto 2jz (ge or gte) flex plate is the same unit as on the 2jzge manual flywheel? Are they compatible?
Thanks
as in a machined shoulder to suit mounting of the auto flex plate gear.... will this shoulder also suit a manual ring gear?
../delete/ban
tech moderator
Thanks for clearing that up Ed.
Would still like further confirmation, anyone?
Just make sure the auto driveplate welding process hasnt made the auto ring too big for the manual flywheel.
Dave
Thanks for the responses, however they seem to be missing the point a little i think.
Perhaps I can be a little more clear;
ed_jza80 has a non standard flywheel, it was designed to have an auto ring gear mounted to it.
I would like to buy this flywheel.
I have a standard manual flywheel (apparently worn beyond repair by machining), I would like to use the ring gear from it on ed_jza80's flywheel.
So I would like to know if a manual ring gear will fit the flywheel designed for the auto ring gear?
thanks
Guess you can't measure it because it's still in the car?
Mos.
No, I can't measure it because its still at the shop that I originally took it to for machining.Originally Posted by Mos
thread in summary -
"we need a jz auto flex plate"
anyone?
../delete/ban
tech moderator
Well my mate might have one as he did a auto/ manual conversion.
yeah I got one if you need it
Ditto, have a 2JZ auto flexplate lying in my garage.
sweet - can someone send to:
Ed Oates
PO Box 956
Penrith BC NSW 2751
PM me price and ill shoot you the $$
first in gets the booty
../delete/ban
tech moderator
You must have a mighty big [PO] box Ed
