Results 1 to 4 of 4
Thread: weird AFM question on 1g-gte
    mel
    Default weird AFM question on 1g-gte
    guys i just happened to see this done in a 1g powered celica and was wondering how it was possible and how it worked
    car was running the std afm , but instead of the afm being before the turbos
    this car /engine had it like this
    pod filter ---- turbo------afm------cooler-----throttle
    afm was placed inbetween the cooler and turbo plumbing and the car was working well
    i just didnt thi8nk that was possible but from what i can see that still doesnt make the airflow anybetter
    any ideas ????????????
    Default Re: weird AFM question on 1g-gte
    It's possible for it to work, don't forget, it's just measuring airflow. From my observations in another thread, once on boost, the AFM is wide open anyway. I can't see any real benefit though personally unless you had more room for it on the intercooler section.
    The other thing would be that the air temp sensor would probably be reading a lot hotter, because it's measuring the temperature of the boosted air.
    When some ppl drag their cars they drop their pod filter/turbo inlet pipes off I guess this setup allows that to be done easily without affecting the management system.
    Like frank said, it should work with no probs. The amount of air that goes into the turbine is (hopefully) the same amount as what comes out.
    *thinks again*
    Ok, maybe that was way out, of course as pressure increases volume decreases and since AFM measures air volume it WILL affect the sensors output. If it was a constant ratio you could factor it in with a programmable management setup, but hmm... AFM readings dependant on boost level, i see a problem!
    But air temp sensors should be mounted as close to the engine as possible to give the temp of the air going into the cylinders, not the temp of the air prior to the turbo or cooler. Unless of course it is an ambient temp sensor for some other form of compensation.
    Timbosaurus...
    You have a catch... Yes, the pressure increase will DECREASE the volume of air going in, but ultimately it's the FORCE on the flap in the AFM that determines how much volume of air is going through. Therefore, so long as the force exerted by said air remains the same, the volume and pressure and alter proportionally to each other and the force exerted will still remain the same.
    All that said....
    The reason for people putting the AFM after the turbos is actually a 'ricey' one. The AFM can quash any turbo noise, or more specifically the turbo "flutter" that occurs when you dont' have a wastegate.. If you put the AFM in front of the turbos, you won't hear the flutter. If the AFM is AFTER the turbos, you will hear more of the flutter.
    Facebook | LinkedIn
  1. Another noob 18RG question
    By tricky in forum Tech and Conversions
    Last Post: 22-02-2006, 12:37 AM
  2. Toyota Vane-type AFM
    Last Post: 20-02-2006, 12:15 PM
  3. afm and pod filter....
    By mrxplode in forum Tech and Conversions
    Last Post: 16-02-2006, 04:21 PM
  4. ae86 / ke70 comparison question
    By BeRad in forum Tech and Conversions
    Last Post: 14-12-2005, 06:59 PM
