Results 1 to 8 of 8
Thread: EP82 Brake Rotors
    Default EP82 Brake Rotors
    I am after new front brake rotors for my EP82.
    The issue i'm having is that it's a 1991 model.
    The pre 92 models apparently have a centre bore diameter of 54mm, whereas the post 92 EP82s have a 55mm centre bore.
    I've contact v-sport, Race Brakes Sydney, and have had no luck so far. The specs i'm after is as follows:
    Vented rotors
    254 mm diameter
    18mm thickness
    43mm Height
    54mm CBD
    4x100 PCD
    After slotted discs if possible.
    I've been able to find the discs with a 55mm centre bore, but it's not 54mm now is it!
    Any assistance/guidance would be much appreciated.
    New Zealand
    Default Re: EP82 Brake Rotors
    tried toyota??
    please, no more PMs!
    No i haven't - as mentioned i'm after slotted discs.
    New Zealand
    oh whoops didnt see that bit!
    Off the top of my head those specs look pretty close to the series 2 ae93 sx ventilated fronts, should have no problem getting slotted to suit. Have you got your hands on a dba/rda catalogue and had a scan?
    Toymods Club Member
    Convictania
    check out www.austarletclub.com and try a guy with username "Brad"
    if not him, post up in the wanted section there, should have some luck.
    If you've treid all that, yeah.. I'm not sure.
    Thanks guys,
    Yeah, i tried the above suggestions already. I'm just going to grab a set of the ones from Brad and i'll see how it goes.
    Jul 2007
    I have DBA's, also through Brad on austarlet.
    They are fine and quick to deliver.
    By The Witzl in forum FAQ
  2. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
