Results 1 to 4 of 4
Thread: What engine oil do you use?
    Lick my hairy Backyard Mechanic Turdinator's Avatar
    Default What engine oil do you use?
    Did a bit of a search and didn't find much. So what oil do you use in which engine and why?
    I've been using Penrite HPR30 SAE 20W-60 in my 3/2TG hybrid.
    I use it because the guy at the store recommended it. I haven't had any problems with it. I think i could do with a thinner grade though.
    Nov 2007
    Default Re: What engine oil do you use?
    I use Mobil SuperHP, heard good things about it, and its relatively cheap too.
    I remember searching the forum on oils to use, and Penrite comes up a lot.
    our tafe teacher runs penrite in his methanol injected 2t sprint car and he says he wont go past penrite
    vic
    jeez 20-60 should be religated to model T's and old tanks..
    i run 0-40w valvoline in the racecar, mainly coz i get it for bargain basement price from work. cant remember what its called, but the valvoline version of mobil 1.
    i run that viscosity to help the car rev, it produces less drag on the engine. the bearing clearances on the 4age are a tad on the tight side, so i know i can get away with it.
    in my road cars, i run whatever i can get for free, but i try to keep it around 10-40w ish for good economy. if the oil pressure is low i then top it up with thicker oil
  1. Toyota Engine Codes Explained
    By wagonist in forum FAQ
    Last Post: 16-12-2015, 12:21 PM
  2. Sams MA61 7MGTE Conversion Guide
    Last Post: 08-07-2015, 12:12 AM
  3. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 07:27 PM
  4. Engineers Cert. Question.
    By Mk3_supra in forum Tech and Conversions
    Last Post: 07-03-2007, 11:49 PM
