Results 1 to 13 of 13
Thread: ABS light staying on
    W.A.
    Default ABS light staying on
    Got a mates jzx90 here and the abs light seems to stay on sorta thing as if there is a fault, and sure enough ABS is not working
    What happens is when you turn igniton on ya hear all the relays etc click away, the lights all go out on the dash to say all good, then about 2 seconds later the ABS light comes on and stays on.
    Any ideas wot it could be?
    Ive pulled out all four of the wheel sensors and cleaned them etc, although they looked fine.
    Is there some way to diagnose the abs system for an error code like ya can with ecu's?
    Matty
    Default Re: ABS light staying on
    in my mcv36 you can plug the it into the diagnostic plug and the bcm with throw a code saying what is wrong with the abs
    often it's either damaged or worn out wiring to the wheel speed sensors or fouling of the sensors themselves, like you checked, and the code will be something like wheel speed sensor input out of range or not present
    W.A.
    hmm so maybe dodgy wiring somewhere then.
    Cos the interesting thing is that the light comes back on even before you start moving the car. Would it even get a signal without the car moving?
    check for any tight crimps in the wiring around the front hubs,
    ive never looked at a jzx, but have had this prob with a few camwee's
    GT-Four Pilot Backyard Mechanic SilverGhost's Avatar
    Seconded, when i got some work done at a mechanic, my car returned with the abs light coming on most times i drove the car. Turned out he cable tied some of the ABS wiring to an exhaust bracket and it melted through and was shorting...
    if the light is coming on straight away then the abs self test has failed, there will be an electrical problem most likely.
    if the abs light come on after you start driving its most likely the sensor/s are dirty or misreading.
    Junior Member Grease Monkey zedrift's Avatar
    N.S.W.
    Has it been converted from auto to a manual shift?Might be the same issue i have with my 1JZ/MX83.
    W.A.
    Quote Originally Posted by PlacentaJuan
    This is exactly what is happening.
    No it has not been converted from auto to manual.
    The car was sitting for about a month, in the time the brake pads were changed and then once the car was re started after sitting the abs decided to come on and stay on.
    What exactly does the self test do mate? any idea? might help narrow down the suspected problem?
    Matty
    just runs some sort of diagnostic check on the eco and stuff.
    i have the abs manual thing you get when you buy the car i think i read about it in there, and im pretty sure you can pull codes via abs light flashing- different from pulling ecu codes.
    ill try to remember to have a look when i get home.
    Quote Originally Posted by Wildsupra
    Matty
    Whilst the brakes were being changed, the ABS wiring has been disturbed.
    cheers Chuck.
    MS51Crown Coupe,
    W.A.
    but the abs wiring isnt even near the caliper......
    and ive looked over the wiring and it seems fine, no obvious problems.
    my abs wiring has seen a hard time, dropped the whole strut with only the abs wire hanging it on and my abs still works fine
  1. 1jz- no engine light
    By AeRoKaBn in forum Tech and Conversions
    Last Post: 04-08-2011, 10:59 PM
  2. 1jz oil light, how does it work
    Last Post: 30-12-2007, 02:23 PM
  3. ep91 starlet, air-bag light staying on !!!
    By boos_rolla in forum Tech and Conversions
    Last Post: 29-11-2006, 09:22 AM
