Results 1 to 15 of 16
Thread: 7M CT-26 same as 3SGTE CT-26?
    has no Toyota anymore :( Conversion King tooch's Avatar
    Default 7M CT-26 same as 3SGTE CT-26?
    Just wondering if the ct-26 is the same across both engines? May be able to get one cheaply and was just wondering if it will bolt up to my 3S?
    Ta
    Default Re: 7M CT-26 same as 3SGTE CT-26?
    nope.
    twin entry and ceramic turbines are a start
    Ahh yes of course
    Thanks mate
    James is right. But now you can tell me where you can get a 7m CT26 for cheap
    SHE LIVES!
    There is one on ebay. Buy it now for $399, no shaft play, no oil leaks, comes with everything.
    Junior Member Chief Engine Builder Classique71's Avatar
    Also australian spec and group a spec 3sgte ct26 were twin entry and steel , not ceramic..
    hence why the mongrel is boosting happily
    Saphira - ST205 Celica GT-FOUR Group A NZ No:1/4
    "Mongrel Garage - back on Aussie soil! "
    165 engines also had a single entry hot side and steel wheels.
    7M turbo is similar to the Gen 1 3S turbo but is large in the exhuast area.
    165 and 7M turbo are interchangable as they are both single entry and steel , The comp wheel on the 7M is larger , the rear wheels are the same size but the 7m has a larger rear housing , the rear housings are also interchangable between the two as the wheels are the same .
    trevor
    Yep, i'll second that, i've done it on my car before but you will have to modify the wastegate actuator as the mounting on the comp housing and the length of the rod are different.
    Mmmm Bickies Domestic Engineer GriZZly's Avatar
    why do u need a new turbo anyway tooch?
    id offer you mine tooch , if yyou wanted to keep it up to spec - do you still have standard exhaust or not ? ( and do you want to keep yours originalish )
    if so - it would be an easy upgrade - though, Gt series turbos are pretty cheap these days to get setup
    Soarin' thru the streets Backyard Mechanic
    How much would a 7m ct26 go for usually these days? Assuming still in perfect working condition...
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    Quote Originally Posted by iSOARu
    usually around 300 i think.
    i was going to post in this thread but everyone else already said the answers
    Well the reason I wanted to replace it, was because mine is getting a little smoky. I am pretty sure it's the turbo, was willing to replace it anyhow as its getting old. However, I'm now seriously considering re-borrowing on my loan and going all out with an engine rebuild (forgies, MHG, etc) and a nice shiny garrett turbo
    Thats a big ask for a 15 year old + turbo :-)
  1. 3SGTE in AE82 Corolla
    By tai_180sx in forum Engine & Driveline Conversions
    Last Post: 02-05-2006, 08:58 PM
  2. 3sgze Vs 3sgte
    By NeoNasty in forum Tech and Conversions
    Last Post: 18-02-2006, 04:03 PM
  3. Bigger injectors 3sgte
    By Jorrs in forum Tech and Conversions
    Last Post: 05-02-2006, 10:41 AM
  4. 6M and 7M differences???
    By fatboy13 in forum Tech and Conversions
    Last Post: 10-01-2006, 08:20 PM
  5. 3sge - 3sgte CAS - interchangable?
    Last Post: 20-12-2005, 09:15 PM
