umm arn't mz12's the same as ma61's?![]()
Does anyone know if F series Diff flange the same as E series?
I'd like to change the Z12 diff flange to the much more common F series, as opposed to the current G series it is atm.
From my MX62 cressida memory the single piece shafts have replaceable unis, and fit to a E series diff...if the E series flange is the same as F series then I might grab the rear flange and uni from a MX62 cressida...
It'll make it easier to put different diff ratios in it (i.e. the MA61 lsd I have for it)...I won't have to change the front flange on the diff...
No.Originally Posted by japlish
MZ12 Auto has an F series diff (3.58 ratio) with a G series flange.
The MZ12 Auto tailshaft has the larger G series (hilux) style replaceable uni as well. MA61 has smaller non-replaceable from factory unis.
MZ12 rear shaft is also longer than MA61, and the MZ12 auto yoke is A340E not A43D as found in the auto MA61.
As a not MZ12 Manual actually has a G series diff according to the EPC...
i'm 90% sure they are.![]()
beer me!
just checked the various diffs i have![]()
the bolt patterns are the same, not 100% sure on the spigots though as the E diff was still in car with tailshaft attached.
bolt pattern was 55mm square (EDIT: may not be square, i didn't check), ~77mm PCD. the spigot on the F diff is 45mm dia.
beer me!
I just went and did a quick measurement of what I have..
joecoolmk2: Any chance you measured the F spigot to be 46mm as opposed to 45??
F Series Diff Flange: (RA65 Diff)
55mm x 55mm Square [Checked]
~45.9mm Center bore clearance for spigot on tailshaft flange (~45.85mm OD for spigot on tailshaft flange) [Checked]
G Series Diff Flange: (MZ12 Tailshaft)
60mm x 60mm Square [Checked]
ive seen at least a couple different bolt pattern on F series diffs. the smaller size same as T series
would anyone have one of these G series mz12 diffs available for sale? even just the housing and shafts![]()
-Mark
E2 + E7 fan
Originally Posted by wilbo666
yeah could be, i just glanced quickly over it with a tape measure.![]()
beer me!
Wilbo if you want to part with that g series yoke for the f series diff just let me know as you may remember i was looking for one before.
Pete
1989 white supra 7mgte manual
http://www.toymods.org.au/forums/for...pra-turbo.html
I'll prbly be looking to sell the whole diff, but I'll keep you in mindOriginally Posted by pete05
