Just as a warning, there are a couple of different styles depending on which dizzy you had. The stock 4K one that I had (and might still have sitting up in the carport, I'll go check) is different to the one from the 4KEU electronic dizzy I put in.
Morning all, I'm in desperate need of some measurements off the plate which holds a K series dizzy into the block. Looks a bit like a mini-clutch fork and is held in place by a single bolt.
If anyone can measure:
- the length from the bolt hole centre to the end of the fork handle (the end with only one prong, not the two prongs)
- The width of the entire thing at the bolt hole
- The width at the end of the handle
I'd be very appreciative. Rough measurements are fine, even a photo of the thing next to a ruler would do.
Reason behind this is I really need to send off some drawings today and I screwed up last night and forgot to take some measurements. Now I don't have the part to hand.
Thanks in advance
Hen
Aah. I know the one I have is from a 3K, in a KE20 from memory. With the forked end 30mm in diameter.
I've designed an adaptor for it and am worried that the fork wont bolt to it properly, and I don't currently have the needed measurements to check.
Hen
Length from bolt hole centre to narrow end = approx 25mm
Width at bolt hole = approx 30mm (the whole thing is tapering though)
Width at narrow end = approx 15mm
Width at wide (pronged) end = 45mm
Just checked, the 4KEU dizzy doesn't have a fork, it has a slotted plate cast into the body of the dizzy, so it only has a limited range of adjustment (was a pain getting it and the oil-pump drive aligned at the same time, and then still having enough adjustment to advance the timing afterwards
