Results 1 to 4 of 4
Thread: Stiffer rear spring on markII?
    Lillehammer
    Default Stiffer rear spring on markII?
    Hi
    Im in need for some stiffer springs on my markII, im towing a lot of trailers with my old car, so i need something that can take a lot heavier load back there, but at the same time i dont want it to be uncomfortably stiff without a trailer on either.
    Im wondering if i can use springs from some other kinda car, maybe cressida, hilux or something like that?
    King springs isnt a option since i already researched that and the shipping to europe is way too much.
    Thanks in advance for any suggestions
    Jun 2007
    Default Re: Stiffer rear spring on markII?
    Find a Progressive rate spring (Eibach) which suits the markII rear vehicle weight and original spring dimensions but does not lower the vehicle, maybe even raises the vehicle 5-10mm.
    Lillehammer
    Thanks for ur answer.
    any suggestion on how i can compare and find the spring i should use? the markII isnt listed with eibach, so i dont really have parts numbers or anything to compare with.
    Jun 2007
    Give Eibach a call with the dimensions, no of coils and thickness of the MarkII Spring and see if they can help you.
    If they can't, I will find out what model should be interchangable for you. What year Mark II is yours btw ? Do you have a picture of it ?
    By The Witzl in forum FAQ
  2. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  3. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
