Caliper Specifications:
A:=Mounting offSet B:=Mounting holes C:=Rotor GAP D:=Caliper Width E:=Caliper Height
Hilux S12W A:28.9mm B:88.9mm 3.5inch C:23.3mm D:103mm E:63mm 4 Piston @ 43.5mm weight 5.2Kg each with out pads
Hilux S13WB A:31.2mm B:88.9mm 3.5inch C:28mm D:112mm E:63mm 4 Piston @ 45.3mm weight 5.7Kg each with out pads
Hilux 'small' S13W A:31.5mm B:88.9mm 3.5inch C:29mm D:112.5mm E:72.5mm 4 Piston @ 45.3mm
Jag XJS A:32.5mm B:88.9mm 3.5inch C:27.3mm D:106mm E:77.25mm 4 Piston @ 43.5mm
Porche 911SC A:30mm B:88.9mm 3.5inch C:23.5mm D:98mm E:70mm 2 Piston
Mnin AP Racing A:35mm B:88.9mm 3.5inch C:25mm D:145mm E:85mm 4 Piston @ 37mm
Other Caliper spec Size approximate
Kelsey Heyes A:30mm B:70mm C:25mm D:96mm E:75mm 4 Piston
Porsche 944 Turbo A:45mm B:95mm C:27mm D:105mm E:?? 4 Piston
FC3S RX7 A:30mm B:160mm C:25mm D:100mm E:80mm 4 Piston
Skyline R33 A:25mm B:100mm C:34mm D:98mm E:80mm 4 Piston
Fitting the crown MS65 hubs and Hilux calipers to the XT130 strut.
I found the S12W caliper sit proud of the hubs by 6.5mm.
Fitted some different wheels and the calipers cleared the wheels no problems.
