Results 1 to 4 of 4
Thread: cranking engine without plugs = bad???
    Default cranking engine without plugs = bad???
    If i crank an engine (in this case ford 4.0L) without the plugs in the leads, what is likely to fail first?
    Default Re: cranking engine without plugs = bad???
    Are you talking about turning over the engine without the spark plugs in and the lead just hanging down sparking against the block??
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    Feb 2007
    Timaru
    Quote Originally Posted by jeffro ra28
    If you dont dis-able the coil, probably that.
    As if there is nowhere for the spark to go,
    it jumps internally and can stuff the coil.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Quote Originally Posted by ra_28
    Yeah. Sparking against block.
    I just check spark from coil = NONE
  1. Toyota R Engine History
    Last Post: 02-12-2011, 09:41 PM
  2. MA70 --> JZA70 Conversion
