Results 1 to 8 of 8
Thread: Help! mx83 instrument cluster wiring vs JZX81 digital cluster
    Default Help! mx83 instrument cluster wiring vs JZX81 digital cluster
    Hi all im in the process of swapping my MX83 analogue cluster to a JZX81 digital cluster.
    Does anyone have any lists of wires for these clusters? the jzx81 cluster i have is almost all labelled as is the mx83. There are just some wires im not sure of where they go.
    Does anyone have any diagrams or lists from when they have done this conversion?
    or if i ask for pin numbers would someone be able to help me? (i had a 302 carby motor in an ma61 so im electronically challanged)
    Blake
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
    Default Re: Help! mx83 instrument cluster wiring vs JZX81 digital cluster
    the main ones im struggling with on the mx83 dash are
    from the back of the cluster LEFT TO RIGHT as you look at it from the back.
    PLUG 1 (12 pin) PLUG2 (10 pin) PLUG3 (transmission) PLUG 4 (10 pin)
    Plug 1 - pin 11 and 12
    Plug 2 - pin 4, 8, 9, 10.
    Plug 3 - pin 10 and 12
    Plug 4 - pin 1, 2, 3, 4
    i "think" these generally relate to tacho, speedo, temp and fuel with maybe illum and earths/ ign power? as i have found all the warning lamps
    thanks
    Blake
    NQLD
    I know you need a digital fuel sender for the tank if you want your fuel guage to work
    User Conversion King
    NWA
    why dont you run the analogue cluster?
    i prefer it instead of the speedo reading
    0, 22, 48, 75, 120
    FYI; i put a MX83 a340e speedo drive in the aristo box and run a cable
    hello
    yeah i heard about the fuel sender thanks mate.
    I actually like the digital dash's. And it has 276000km less than my analogue one does! plus the 7m tacho wont work with the 2j without a booster.
    brett do ytou have any info about the pins on the plugs?
    Quote Originally Posted by Robbos_Toyotas
    Easily Fixed
    And easily fixed
    ps I'm no help on plugs
    Have a search, I posted a link to the digital dash pinouts a few months back.
    Junior Member Grease Monkey chaserbuddy's Avatar
    Feb 2008
    thanks
    Blake
    Hey,
    i guess uve probably done it by now but anyway here you go.
    i did this with a mark ii so unsure if the signals are the same. should be
    Plug 1 - pin 11-temp and 12(temp resistor maybe)
    Plug 2 - pin 4-earth, 8(light signal +ve?), 9(earth), 10(nothing)
    Plug 3 - pin 10(unsure) and 12(unsure)
    Plug 4 - pin 1-ignition +ve, 2(sender signal), 3-earth, 4(not important)
    I changed from digital to analog which wasn't that difficult.
    cheers.
  1. JZX81 digital dash into MX83
    By Cressida91GLX in forum Tech and Conversions
    Last Post: 10-06-2009, 07:47 PM
  2. 1jz Jzx81 -> Mx83 Abs
    By mamba in forum Tech and Conversions
    Last Post: 21-11-2007, 08:28 PM
