Results 1 to 15 of 23
Thread: Autonic SM4 + 1JZ
    Roll Ons? Carport Converter Endless's Avatar
    Default Autonic SM4 + 1JZ
    Considering selling my LT12S and going for one of these down the track, i know the awesome thing about the Microtech is the fact you can use all the stock sensors etc..
    What i'm wondering is basically what is needed apart from the ecu itself to get one hooked up to a 1JZ?
    Default Re: Autonic SM4 + 1JZ
    buggerall?
    plug and pin kit, 1 or 2 sensors, and a nerdy guy with an Asian fetish
    Yeah not heaps hard to do, there are a few options when it comes to how much more you want to spend. I wired one up for a mate last year.
    Wanna upgrade your coils?
    Standard ones have the cracking problems, & seem to struggle with decent power increases, and of course heat. There's lots of upgrades out there, all of which work pretty well but vary wildly in cost. We used second hand LS1 coils ($100-$200 for 8) which have an inbuilt ignitor, remote mounted with some custom leads ($60 to make yourself) set up to run waste spark, as the SM4 only has the 4 ign. outputs. There is an ign. multipier available to run it fully sequential but all advice was it wasn't necessary.
    Reports from
    The word from US supra people is that the LS1 coils made great improvements on 5-600+hp 2Js, not only in power but at idle & cruise.
    ISCV or Ford idle valve. The Ford Idle Valve is what's suggested by Autronic, is easy to wire up, fairly easy to get second hand/cheap, & I imagine would be much easier to set up, even for an experienced tuner. But requires a mod or two.
    Apart from that the bosch water temp sensor suggested by Autronic is cheap & a straight swap for the standard one, which should work but isn't exactly the same spec as the Autronic one.
    Or you can use stock everything (bar air temp sensor), and hook it up to the standard loom, but running new loom is a decent sized job & is a good chance to do everything properly....
    Forum Sponsor Conversion King
    Dec 2006
    Quote Originally Posted by BigWorm
    the bosch one is about $40 from memory and considering you dont need to put any values in the ECU makes life easy.
    linden
    Angry Re: Autonic SM4 + 1JZ
    Quote Originally Posted by Draven
    Oi!!! I'm not nerdy!!!
    Interesting... so you can run the factory ISCV with them then? It just requires a bit more work to set up?
    There are plenty of big power 1J and 2JZ's using the stock coils so i don't see any need to replace them for no reason, i have a good condition set i recently bought.
    Can the SM4 utilize the factory igniter?
    I am also under the impression they have an inbuilt boost controller, is there any kind of hand controller or can you hook up an external switch to run different amounts of boost?
    depends what power you want out of your engine... my coils have run out
    Quote Originally Posted by Endless
    Yep you should be able to.
    Most of them have some sort of ign. "enhancers", with new or just newer coils though. An ign. upgrade is a pretty good idea, especially when it can be done fairly easily & cheaply.
    I believe you can use the standard ignitor, it may have to be wired up for waste spark though, which might over work it a bit.
    Pretty sure you can hook up a switch for that, there's plenty of spare inputs to use.
    Download the SM4 software, & in that is the wiring diagrams. That'll give you an idea of what it's capable of.
    Quote Originally Posted by Mos
    i love how you dont deny the asian fettish though
    (having never met you nor knowing what you look like)
    also i know of at least 2 peeps on here that will take the microleb off your hands
    Haha yeah thanks i'll keep that in mind, doesn't look like it will be a problem should i decide to sell it.
    Where can i download the software for it?
    Quote Originally Posted by SillyCarS
    yeah I could be one of them
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    yeah
    you and i both, ive got dibs, but i have mo money and mo turbro
    yeah but what you gonna put it on?
    the 1G?
    you will need to send it back to microleb HQ to have it reconfigured to suit one gee
  1. 1JZ vs 7M alternator useful info and pics
    Last Post: 22-06-2009, 04:10 PM
  2. 1jz to 2jz
    By HIZOKU in forum Tech and Conversions
    Last Post: 30-11-2006, 06:52 AM
  3. 1jz vs 2jz heads
