Results 1 to 14 of 14
Thread: water leaking into boot TA/RA23
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Default water leaking into boot TA/RA23
    hey,
    the boot rubber on my 23 was pretty shit, i went out and got a new one and still no change
    any one have any past experience on this topic, any help will be appreciated
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    senior backyard mechanic Grease Monkey legend's Avatar
    Default Re: water leaking into boot TA/RA23
    looks like its get in the boot time with the torch and shut the boot and get someone to hose the boot area to find out where its coming in exactly
    Ibzzzz, Its good to see you around mate!
    Water used to get into my boot in the top left corner. Would run down the length of the window, down into the channel where water is supposed to run, but instead of falling off the back of the car, it was getting in along that channel. I reckon sitting in the boot wouldnt be a bad idea. But with your fuel pump and surge, you may get a wee bit high
    Jase
    JZA023
    I had a leaking boot rubber in my ra40 (hatch) same deal with me, new rubber didn't fix the
    leak, and did the same as smokey228, so I ran a thin bead of black silicon along the sides
    and top corners under the rubber. still leaked but not as much, then I took the hinges off and
    ground half a mm off them (just the top of the hinge) and that fixed it for good.
    Edit, oops .. what i ground off was surface rust between the hinge and hatch.
    Check the tail lights aren't leaking, I had trouble with them on my ta22s
    I am the sun
    Tali lights and was there any points under the boot rubber that had rusted through as no boot rubber will stop that,also have you still got the little rubber grommet that sits where the original jack sits? might be coming up into the boot rather than dropping down,which with all this weather lately is easy to do just driving around..
    cheers Nath
    -Just Alloy Radiators-
    www.alloyradiators.com.au
    Jun 2007
    victoria
    i have the same problem with mine leaking in through the rear window, water collects and seeps in on right side bottom
    I'd suggest the window also. Prime rust loacation.
    Im with LeeRoy... the bottom corners of the rear windscreen rust like buggery and let water in without you knowing Otherwise, tail lights.
    whats up ibz's babes? been quiet around here with no rotor bashing
    Us Celica owners are so lucky with all the possible water entry locations. Gotta love 70's cars and rust.
    Quote Originally Posted by LeeRoy
    excactly why they best sit collecting dust in DRY workshops
    Ouch!
    I'd start looking at your rear window. My old 23 used to leak water in through the back window, onto the parcel shelf, then drip in into the boot
  1. water injection pre turbo
    By project_x in forum Tech and Conversions
    Last Post: 28-03-2008, 07:41 AM
  2. Cooling Systems - Overheating Problems.
  3. AE93 CV joint boot leaking; mechanic recommendations?
    By DigitalPho3nix in forum Tech and Conversions
    Last Post: 27-12-2005, 03:36 PM
