Results 16 to 19 of 19
Thread: smallport 4AGE Speed sensor
    Default Re: smallport 4AGE Speed sensor
    any AE92 with an EFI motor generated the 4-pulse-per-revolution speed signal from the back of the speedometer.
    I have heard rumour that some (maybe not all) AE86 speedos have the same ability - look for a point labelled "4P" on the pcb behind your gauges.
    If you dont have it, then you will have the 7200rpm rev cut that I also had with my smallport engine in my old AE71.
    you "could" build a circuit to generate the pulse... it's quite a basic signal really. The only concern i have is the questions surrounding what else the ecu does with that speed signal.....
    Junior Member Domestic Engineer mic*'s Avatar
    Was gonna say that...
    Should be ok tho as long as you arent running an auto??? I cant see how the ECU would dramatically vary fueling.
    meh...
    was hoping your would see this witzl,
    i read that rumor on twincam, and i'm buggered if i can find that point on the back of my spare aussie AE86 instrament cluster (though i have only looked at the plastic PCB thing, dont really want to dismantle the cluster)
    so that means i can either glue magnets to the tailshaft or run a wave generator.
    i look at it like this, is telling the ECU that the cars is always travelling at 50km/h any worse than not giving it a speed signal?
    The Australian cluster does indeed have a speed signal output
    for anyone searching for this info, see
    http://toymods.net/forums/showthread...2110#post82110
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 06:11 PM
  2. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
  3. jzz30/A340E speed sensor issue
    By lumpy in forum Tech and Conversions
    Last Post: 20-01-2006, 12:28 PM
