This is the ABS speed sensor. Its output (32ppr) normally goes to the ABS/TRC computer (in the boot in an *X8*) which then divides this signal to 1ppr for a 7M-GE or 4ppr for a 1JZ-GTE for the SP2 signal. No idea what the pulse rate on a 1G is but if I had to take a stab it would be 1ppr.
You either:
1) Put up with using SP1.
2) Build/obtain a divider circuit which generates the appropriate SP2.
3) Cut/grind enough lobes of the 32pulse sensor to get either 4 or 1 lobe left.
The other two wires are ground and power, both supplied through the ABS/TRC computer.
BTW, this topic has been covered to death many times
Mos.
[/IMG]
