Results 1 to 10 of 10
Thread: Wiring DIY fuel cut
    Junior Member Grease Monkey ripfast's Avatar
    Default Wiring DIY fuel cut
    I want to make a DIY fuel cut defender from the thread; (as pictured)
    http://www.toymods.net/forums/showth...=fuel+defender
    My question is how exactly is it wired up.
    do you cut the wires going to and from the map sensor or just wire in the components?
    so for example the signal wire would go into the MAP and have the diodes coming off of it before it goes into the map.?
    hope this is explained ok
    1985 VK Commodore with 1JZ-GTE
    1989 GZ20 GT-T Soarer with 1G-GTE
    2008 IS250 with not enough power
    Default Re: Wiring DIY fuel cut
    you have to cut the map sensor signal wire and wire the fcd in series (like an ammeter)
    hey didnt your commo get stolen a while ago or something?
    Aug 2006
    Try this one, all the info you need
    http://www.teamfc3s.org/info/articles/fcd/diy_fcd.htm
    yeah the commo was stolen almost two years ago. been sitting in the shed ever since. I gradually just been fixin it up, now its registered and has a new 3 inch zorst with dump pipes, (never had a good exhaust before thats why i need the FCD fitted) just a bit of panel work to go.
    Officer Doofy will the easier FCD on this forum do the same thing?
    User Conversion King
    NWA
    yep,
    ive built and used the type with 2 diodes + 1k pot on a 1JZGTE and 2JZGTE and work great.
    you dont have to cut the map sensor wire either.
    just splice into it.
    hello
    yeah so basically on the pic in the link , the dots on wires are where you splice into the wire.
    the harder fcd is better.
    there is an article about why but i cant find it.
    the easy fcd 'bleeds' boost signal to the ecu weather you are at 5psi or 20psi, which leans out your mixture across the whole rev range
    the hard one will only kick in at the boost level you set it, is set at 18psi and any boost level signal UP to 18psi will not be altered going into the ecu.
    NWA
    Quote Originally Posted by PlacentaJuan
    not the one we are referring to with 2 diodes and a pot.
    when the map sensor voltage is higher then the pot voltage, the circuit is clamped at the pot voltage.
    you are probably referring to the type that is just a grounding resistor which will scale the signal
    hello
    no worries i might try the easy one to start off with
    heres the link i was thinking about, applies only to 2jz though.
    http://www.mkiv.com/techarticles/bcc...GReddy_BCC.htm
  1. TA22 fuel tank sender and gauge
    By 4SFED in forum Tech and Conversions
    Last Post: 26-06-2007, 12:07 PM
  2. Fuel Pump problem
    Last Post: 30-05-2007, 05:58 AM
  3. Car dying all of a sudden - Fuel pump?
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 28-05-2006, 12:27 PM
  4. MS85 Fuel Pump.
    By Brad-KE35 in forum Tech and Conversions
    Last Post: 31-03-2006, 09:12 AM
  5. Help! TA22 Wiring Problems!!
    Last Post: 20-03-2006, 09:52 PM
