Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: KKR Aluminium bends
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Wink KKR Aluminium bends
    Hi Guys, i've got some more products i think you will like.
    Offical Release
    New to Otomoto Pty Ltd are these chromed aluminium mandrel bends. Ideal for use in intercooler kits and mounting pod air filters, they are available in both 2.5in (63mm) and 3in (76mm) diameters and are constructed from mandrel bends, all featuring ribbed ends.
    They are also thick enough to be easily cut and welded as needed.
    There are four types of aluminium pipe available with the straight sections retailing for $20.00, 45 and 90-degree bends retailing for $25.00 and the 180-degree bend retails for $30.00. Both diameters are the same price.
    Default Re: KKR Aluminium bends
    Chromed aluminium???
    Polished perhaps?
    No, chromed. I'm told the process is much like anodising.
    Then welding them would probably be a really nasty proposition..
    TIGs don't like coated materiel in my experience.
    True, but it can be done and rechromed.
    Available soon (mid February) will be raw aluminium finish so the bends can be cut and welded then polished.
    Whats the overall width of the 180deg bend?
    I've yet to measure the one on my car, but its not tight enough and fouls.
    Forum Sponsor Conversion King
    Quote Originally Posted by dori dori
    2" and 2.75" also? come on then my life would be easy.
    you can take the coating off with a linisher and weld it as i have done it many times b4 but it does take some getting use to as the impurities come through whilst welding.
    let me know when the raw stuff comes in and ill be there in a flash.
    linden
    The overall width of the 63mm 180degree bend is 280mm.
    The overall width of the 76mm 180degree bend is 310mm.
    linden
    Hi Linden, i will see what i can do on the 2in but i'm not so sure on the 2.75in. not sure how much demand we will have for it.
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    i may also be interested in a couple 2inch 90degree chromed bends..but would want them within the month....
    1977 RA23 Celica -> 1ggte conversion [SOLD]
    MA70 Supra 1JZ 5speed [SOLD]
    Current: IS200 1JZ VVTI 6 speed
    2.75" is most toyota and nissan TB size, demand would be pretty high if you were to put kits together for you coolers to suit a variety of cars.
    2" is the majority of t25 size turbos so should be plenty of uses for them also
    see what you can do and let me know.
    linden
    Hi Linden, will do.
    Damn, same as whats on the car.
    No drama.
    Toymods Club Member #274 Backyard Mechanic Rallystanza's Avatar
    Yer 70mm would be awesome!!
    None of this polish stuff to be had.
    R.I.P Peter Brock.
  1. Aluminium + Oxy Welding, Need some help.
    By ReQuieM in forum Tech and Conversions
    Last Post: 16-10-2006, 01:07 PM
  2. aluminium grade question
    By bullitt in forum Tech and Conversions
    Last Post: 27-12-2005, 12:54 AM
