In the setup with are 1g into an ra28 its the same problem w50 on drivers side and the w58 is on the passengers side. I bought some bundy tube and ran it along from the brake master to a point on the passenger side then a flex line down to the w58 slave. Once i had modded the bundy tube into the right shape - using a wheel brace and two pieces of wood to bend it so i didnt crimp the line at all (guy at the brake store said it was the best home job hes ever seen lol). I got them to double flare it for $15 an end.
This is the best pic ive got:
At the time this seemed like the logical way of doing it rather then have a huge flex line over the potentially hot engine. I was too afraid that it might introduce to much flex.
EDIT: NCOP brake ruling is here if your planning on getting engineered under NCOP.
http://www.infrastructure.gov.au/roa...s_3Feb2006.pdf .Gave it a quick read but i couldnt see 'braided lines' but states the it must be bundy tube and must be double flared. Also 'hoses, cables ets' must be mounted away from excessive heat so over the engine hose is probably not the best idea. Also any brake component/line must comply to a international standard.
