Results 1 to 10 of 10
Thread: 18rgeu Tps
    Aug 2007
    Washington
    Default 18rgeu Tps
    Hello folks,
    Could anyone tell me feeler gauge adjustment numbers for 18RGEU TPS?
    Thank You
    Regards!
    Alex
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    Default Re: 18rgeu Tps
    From memory you just make sure one set of contacts is closed at idle, and another set of contacts are closed at full throttle. Fairly basic.
    This is true, the tps on the 18RGEU are just two switches, one for idle and one for full throttle.
    its actually a 3-position switch.
    one for idle, one for just-off-idle, and one for wide open throttle.
    Just make sure that the idle switch is connected when throttle closed, and disconnects when throttle is just open.
    ...... butt scratcher?!
    Thats interesting Mr Witzl, from memory the TPS I have only has three pins, a common and the full throttle and idl pin.
    Is there another TPS out there with four pins?
    Yeah mine only has the two switches as well.
    I have two three pin ones here.
    (\__/)
    (")_(")
    Yes, they are a three pin item.... HOWEVER:
    AT IDLE - earth and idle pin connected
    AT WOT - earth and wot pin connected
    AT JUST-OFF-IDLE - no pins are connected.
    You guys didnt think of all the possible combinations did you?
    But dood...when no pins are connected..it can by anywhere between just off idle and just off full throttle...
    So technically it would be interepreted as between just off idle and just off full throttle (as under these conditions no switches are closed)
    Rudi
    the WOT pin is connected at around 1/4-1/2 throttle from memory.
    I cant remember, its about 3 years or more that i tested that.
  1. 4agze TPS - fault & setup
    By AE101LEV in forum Tech and Conversions
    Last Post: 24-10-2006, 07:36 PM
  2. TPS Problem
    Last Post: 28-04-2006, 03:10 PM
  3. TPS Idle Switch
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 19-03-2006, 06:44 PM
  4. Full-variable output TPS - what cars ??
    Last Post: 20-02-2006, 12:59 PM
