Results 1 to 6 of 6
Thread: 3sgte Spigot Bearing PART NUMBER NEEDED
    Junior Member Grease Monkey medwin46's Avatar
    Default 3sgte Spigot Bearing PART NUMBER NEEDED
    Hey all
    I've done a search through the interchangeable oddities and the likes, cant find anything on this.
    Basically i need a part number for a 3sgte (ST185) spigot bearing. Now im assuming the W58 input shaft has the same OD as the GT4 box, i do not have a gt4 box to check.
    Need this bearing so i can finally get the engine in the car!
    Junior Member Grease Monkey off-road's Avatar
    NT
    Default Re: 3sgte Spigot Bearing PART NUMBER NEEDED
    Measure OD of input shaft and ID of crank and ring CBC etc and you will be in business.
    They may also require a thickness.
    needle roller or ball bearing??
    sealed ball bearing.
    Forum Sponsor Conversion King
    you can get the bearing in 10 or 13mm, id use the 10mm bearing if i did it again.
    unsure on the rest of the sizes but a quick check with verniers and a call to CBC will have you sorted.
    linden
    The ID of the bearing will be 12mm (this is the diameter of the bit of the W58 input shaft that slides into the bearing). The OD will be 28 or 32mm.....you'll need to check this. Just measure the diameter of where the spigot bearing fits into the back of the crank with some verniers. Go to CBC with the OD and ID, say it's for a spigot bearing, pay $5 and you're in business.
  1. 4AGE spigot bearing help!
    By Starfire in forum Tech and Conversions
    Last Post: 18-12-2006, 08:10 PM
  2. jzx90 mark2 wheel bearing wat asus car has same part
    By tourer.v in forum Tech and Conversions
    Last Post: 08-08-2006, 06:11 PM
  3. vacum sensor part number
    By bassy in forum Tech and Conversions
    Last Post: 09-07-2006, 09:02 AM
  4. AE86 Rear Discs Part Number
    Last Post: 12-03-2006, 04:09 PM
  5. 1UZ-FE part number ID and help needed
    By scootaphill in forum Tech and Conversions
    Last Post: 09-01-2006, 03:26 PM
