The stock head gasket from toyota for the 20valve is 1.6mm before compressed and goes down to 1.2mm so thats for the normal set up. the trd metal head gaskit is 0.8mm either one of those is fine to use for compression etc. It is true about the engine being a interferance engine ie. timing belt breaks there goes the valves and then in need of a rebuild. but a good timing belt and getting it changed at the right times will be safe. lots of people including myself have run this setup. which pistons are you using the gze gen1 or gen2? as the compression is different between the two
