*I'm assuming you have pull fans here, not push*
Fans need to be spaced back from the radiator to work correctly, and they need to be completely shrouded so that all the air is going through the radiator, and not around it.
Fans bolted directly to the radiator will only the cool the section they cover (ie, in your case, two 8" circles).
That said, fans do nothing at speeds over about 60kph.
If you are having cooling issues at cruising speeds, then either the ram air isn't enough, or getting too hot, or the water system isn't keeping up.
If you are having coling issues at speeds less than 50kph and at idle, then chances are your fans aren't doing a good job (radiator could be blocked too).
A pic of your setup will help determine the problem.
Although, from your post, I don't think you are having issues, but you are worried you might have some.
