Results 1 to 6 of 6
Thread: AW11 flywheel Q #2
    When ASIO calls I'm a Backyard Mechanic McFly 11's Avatar
    Q
    Default AW11 flywheel Q #2
    Get ready for the noob Q of the day =)
    After dropping the auto off my AW11 in preparation to install a manual box, I found the auto "flywheel" had 2 metal plates with 8 holes (to match the bolt pattern), one on either side of it, as spacers/washers.
    These aren't mentioned in the BGB at all. Are they to be reinstalled with a manual flywheel, or should one (or both) be left off?
    Luke / McFly 11
    Default Re: AW11 flywheel Q #2
    get rid of the whole thing. Bolt on flywheel with new bolts from toyota torqued to spec.
    the auto "flywheel" is actually called a flex plate. As Cuzzo has said, remove the whole lot, and install the correct manual tramsmission flywheel and 8 new toyota or ARP flywheel bolts. You'll also need 6 clutch cover bolts as well.
    Current Cars:
    Q
    Thanks mate,
    Got the new bolts and MT flywheel together all ready to go . I'll bin the spacer/washers off with the rest of the AT gear then.
    Edit: Thanx Psycho - I was aware of that (although I would have used 'drive plate' as per BGB) but to save confusion I used the commas instead
    Q
    I had them loosely-fitted with the MT fly but they are off now Here is a reference pic of the spacer and washer plate thingy:
    New Zealand
    yeah i recently had a customer have an issue
    aw11 getting a 20v.
    donor motor was auto
    he fitted those spacers
    lucky he found the source of the rattling before the flywheel came off.....
    please, no more PMs!
  1. Aw11 4agte
    By mr2janai in forum Tech and Conversions
    Last Post: 19-08-2006, 07:13 PM
  2. What flywheel is this?
    Last Post: 11-07-2006, 09:40 PM
