you may want to be a bit more specific ie:
do you want a larger/stronger diff
or
do you want some different ratios, and if so what ratio are you chasing
or
are you chasing a better LSD than the factory offering?
linden
What else fits, besides the factory 4.3:1 ?
I heard some 4x4's can work, but which ones?
SWAMI Garage
or
or
linden
Originally Posted by WHITCHY
im looking for different ratios primaraly
anywhere between
4.5 - 5.1:1
and maybe a better LSD later on
SWAMI Garage
My experience is the reverse (I fitted an Altezza centre to an earlier live axle diff) but it seems the Altezza uses an F series diff, so parts from other F series diffs could well be interchangeable. There's plenty of info around here about the Fs.
However someone with more experience than me can confirm if the bits do swap over easily.
Hen
I've seen the threads about the center sections being interchanged.
But there is no mention of the crown and pinion gears being swapped.
SWAMI Garage
well if the centre is the same, it will take the same crown
please, no more PMs!
