Results 1 to 15 of 15
Thread: Biggest alternator for AE101 4AGZE?
    Chiba
    Default Biggest alternator for AE101 4AGZE?
    Just wondering what the largest alternator that will fit my AE101 4AGZE Levin is, in output current.
    I'm going to be installing a killer audiosystem (active 3 way dynaudio splits, Image dynamics sub, 4 amps etc etc) and want to make sure my electrical system will keep up.
    What have people used or reccommend?
    Thanks.
    Default Re: Biggest alternator for AE101 4AGZE?
    2nd battery + capacitor as part of the stereo install... i believe it was like a motorcycle battery..
    Junior Member Backyard Mechanic KARNAGE's Avatar
    Yeah my old car i just ran a double battery sytem with a very good quality battery which worked perfectly never had a problem and that was pumping out 144db without dulling the lights
    Chiba
    I'm not keen on capacitors, tried them before and have had better results with upgrading cables.
    Dual batteries is an option, but I'm relocating to the boot to allow for a custom airbox, so they will both have to be in the boot. I'll be using an Optima Yellowtop (their highest capacity), but I'll be running about 2000WRMS of amps.
    I'm worried that 2 batteries, 4 amps and a subbox for a 12" sub won't leave much room.....
    Apparently I'm a Backyard Mechanic PULSE's Avatar
    I know you can get aftermarket alternators that pump out like 200+amps, I've seen people talking about them on audio sites like fibreglassforums.com and mp3car.com
    cd player $120, pair of 6"s $50, rest on GO
    good call lol. but if your wanting to do it the yellow top batteries will power that with no worries what so ever some of the boys up here are running ther wattage with the one battery and they haven't had any problems. But if you are interested in the bigger alternator in the classifieds on this site someone was selling high power alternator 130amp and all you need is your old alternator they just change the internals etc.
    Chiba
    PLENTY being spent in both departments. No worries there....
    I'll have a look KARNAGE, sounds interesting.
    Anyone know what the stock current output is? I didn't think to check and I'm a 3 hour drive from my car.....
    AB
    stock is 120 amps, i think that toyota made an alternator for 140amps.... i believe they were in GZE mr2's......
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
    Chiba
    Cool, I'll have a look once I'm back in town.
    look to the yooropean cars. i know they have ones around the 200amp mark and more.
    they get expensive quickly though
    hmm, current mercs seem to have 180 or so..
    i vaguely remember seeing 250amp models, but yah.. not cheap.
    you can also look at using dual alternators etc.. and configuring a charging system from that.
    Got your ute back Nath Grease Monkey 75Ta22LT's Avatar
    - Running an SV21 camry altenator on the 4age.
    Not sure how many amps it throws out but pretty sure its more than the standard one, works fine from my experience.
    Do they fit on to the standard alternator bracket fine?
    That dude with the AE95's Backyard Mechanic Kebin's Avatar
    Constitution Hill, NSW
    Quote Originally Posted by DeftAnesthetik
    120amps???? try halving that!
    4a alternators are rated at around 60-70amps same with the camry sv21 alternators... if anything you would be looking into alternators off larger cars with larger motors i.e. v6 camry's falcon's etc.
    Im currently chasing a bigger alternator for my gze too as im already drawing 40amps from one of my newly added accesories and im still yet to install the stereo system
    KARNAGE Do they fit on to the standard alternator bracket fine?
    - that they do, but as said above, probably the same ampage output as the standard 4age.
    At the time I just needed a replacement.
  1. can other 4AGZE blocks be used with AE101 loom (essentially)
    Last Post: 07-02-2007, 07:23 PM
  2. 4agze questions
    Last Post: 14-06-2006, 09:50 PM
  3. 4agze conversion
    Last Post: 02-03-2006, 09:52 PM
