Results 1 to 9 of 9
Thread: Custom Fuel Rail Fabrication
    Junior Member Grease Monkey medwin46's Avatar
    Default Custom Fuel Rail Fabrication
    Hey guys
    Well im playing around with this damn car still, atleast till it sells, and thought i'll get on top of this fuel rail issue!! i am using these 800cc injectors...
    And have had the locating rings made for the head, now im onto the rail itself. I've made a proto type up, had extrusion and had the holes machines (reamed) out to be a very tight (i say VERY tight as in very tight with lubrication!!) and im just wondering if there is meant to be a more precise way of housing the injectors, considering there will be 40-45psi of fuel pressure pushing its way out of wherever it can?! This is the rail so far...
    as you can see the holes are very very precise (except for one that got a deep scratch through it) as they are hand reamed, not machine.
    Would you say these style injectors are just meant to be a tight fit into the holes or do more housings need to be made and welded to the outside of the rail so to speak? Any advice greatly appreciated. Cheers
    Junior Member Grease Monkey BMWTurbo's Avatar
    Jan 2007
    Default Re: Custom Fuel Rail Fabrication
    You need to 'clamp' the fuel rail to the inlet manifold so that the injectors are 'trapped'.
    You will need to ensure that you collars seal against the inlet manifold also, else you will bleed boost through them... Assuming forced inductino as you have 4x800cc injectors.
    Quote Originally Posted by BMWTurbo
    Yes i should have stated i have made the mounts and everything up so that the injectors are clamped in there, unable to move.
    Im more concerned about the sealing of the o-rings in the rail itself....
    they only need to be tight, not super teenage mutant ninja turtles tight.
    aslong as the Orings seat will they will be fine, once its "clamped" it will all hold pretty tough
    More pics of teh extrusion your using!!!
    where did you get that fuel rail from? EFi hardware?
    It doenst look like the ones i have seen/used in the past
    which includes teh stuff from EFI hardware
    Penrith BC
    i have the same extrusion,
    got it from a place in syd (cant recal the name, but can if requested)
    cost about $75 for 1.5m length
    ../delete/ban
    tech moderator
    Penrith BC
    ../delete/ban
    tech moderator
    Im not sure that is the same, yeah the profile is but most of them have the same profile
    although the quality of his pic is bettter this looks quite rough where as what i have used in the past has alwasy been well finished like whats yours looks like
  1. Fuel cooler / fuel temp
    By Pearce in forum Tech and Conversions
    Last Post: 12-05-2007, 08:55 PM
  2. (BNE) after custom fuel rail (drilled to my measurements) asap
    Last Post: 05-01-2006, 07:11 PM
