Results 1 to 9 of 9
Thread: Oil in spark plug pots
    Jul 2007
    Default Oil in spark plug pots
    Hi all,
    A friend of mine has an old apolla/camry with a 3SFE 2l engine in it.
    He came round to my place to help him with a service and I found oil (look used) in the pots.
    Any ideas how it got in there and how to stop it?
    Grfoos
    Beer Fueled Domestic Engineer doobs's Avatar
    Default Re: Oil in spark plug pots
    Quote Originally Posted by Grfoos
    Hi all,
    Grfoos
    The cam covers have leaked, to get it out, try using a large syringe, and some absorbent rags.
    You will probly notice about 6 phillipshead screws holding each cam cover down, tighten these up, should help... you may also need to replace the camcover gaskets...
    Could also be from the last service and some spilled oil. Depends on which pots the oil is in really. If it's the 2 closest to the filling cap, I'm pretty certain what the cause is
    Junior Member Grease Monkey 3BarSuperstar's Avatar
    Nov 2007
    Are the spark plug tubes inside the rocker cover or does it run seperate rocker covers like a 4a? If it has the tubes it is probably the tubes them self have leaked. You need to remove the tubes and reseal the bottom of them. They screw in by the way.
    Tasmania
    they run one around the outside of the rocker cover, then a smaller one that just goes around the spark plug pots 2 and 3. The gasket itself is a like a big shapped rubber "o" ring that sits in a groove on the underside of the rocker cover.
    Ide say its most likely leaking gasket because this is a common 3s problem
    1973 TA22
    wa
    they will be leaking where your spark plug tubes screw into your head (the thread part)
    take off the rocker cover and you can use two of the nuts locked together to screw them out or you can use some multigrips to unscrew them
    if you use the multigrips dont damage where the top seals(under the rocker cover nuts )sit this area will be clean
    try to turn them on the part that is stained with oil
    they will be tight but will unscrew if you turn them anticlockwise
    remove all 4 of them clean them up with a wire wheel(bench grinder) and put some toyota black sealer or similar on the threads (lots) and then screw them back in
    and refit rocker cover
    Tasmania
    do they run a seperate tube? or are the like the "ge" heads and have the spark plug holes as cast into the rocker cover with a gasket around it?
    1973 TA22
    wa
    separate tube mate
    I have resealed thousands of them now
    Apr 2007
    The ones i have come across leak from the top seal of the spark plug tube, just tighten up the big nuts underneath the spark plugs leads.. dont go too tight though ..Or at worst just replace the seals inside the cam cover ...
  1. Wasted Sparks VS Sequential Spark
    Last Post: 08-01-2018, 12:19 AM
  2. Oil in spark plug chamber 3sfe
    By dundee230966 in forum Tech and Conversions
    Last Post: 10-04-2007, 12:46 AM
  3. 4AGE Spark Plug Cover
    By AE92 Rolla 4A-GTE in forum Tech and Conversions
    Last Post: 29-10-2006, 06:13 PM
  4. Spark Plug Question
    Last Post: 22-05-2006, 08:09 PM
  5. Spark plug stuck
    By smt_007 in forum Tech and Conversions
    Last Post: 18-01-2006, 08:58 AM
