Results 1 to 9 of 9
Thread: Spigot bearing for JZX100
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    Default Spigot bearing for JZX100
    Hi, I'm trying to track down a part number for a JZX100 for the spigot bearing. Any ideas? I'm assuming it is a 6201-2rs but just want to double check...
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    Bunbury W.A.
    Default Re: Spigot bearing for JZX100
    Surely someone can help?
    I used a JZA70 one in my JZX100 vvti 1J
    Apr 2007
    I reckon it's be the same as any other R154 equipped car. 6201, 32 OD 12mm ID I reckon is the one you want, to suit a 1JZ. Same as a 7M also.
    just checked the good old epc, and yes it's the 6201 you want, matched to over 100 models in my epc!
    Bunbury W.A.
    Cheers! Rep to all those that helped...
    Junior Member 1st year Apprentice tin can's Avatar
    Hi all
    The genuine part number is 90363-12002
    I have them is stock
    Hope this helps
    Rrp: $12
    jess
    im not a Mechanic im a parts interperter
    current project: ke70 with 3tet
    now with 114kw on 10psi
    Roll Ons? Carport Converter Endless's Avatar
    Just an added question, with an aftermarket flywheel / twinplate am i correct in thinking the size would differ?
    Apr 2007
    no offence tin can, but i got one the other day for 3 bucks.
    Nah it should be the same because that bearing is sized in reference to the input shaft, nothing to do with the size of the clutch.
  1. Spigot bearing removal pictures.
    By maurice c in forum Tech and Conversions
    Last Post: 18-09-2010, 11:26 AM
  2. 4AGE spigot bearing help!
    By Starfire in forum Tech and Conversions
    Last Post: 18-12-2006, 08:10 PM
  3. 1GGZE Spigot Bearing Part No. Reqd
    By infotechplus in forum Tech and Conversions
    Last Post: 03-12-2006, 09:51 AM
  4. C52 Gearbox and Spigot Bearing
    Last Post: 15-10-2006, 03:25 PM
  5. Replies: 31
    Last Post: 25-04-2006, 10:00 PM
