Results 1 to 10 of 10
Thread: 4agze Clutch problem
    GameOn Backyard Mechanic Poggy's Avatar
    Default 4agze Clutch problem
    Hey Everyone
    I have an ae82 with an ae101 gze, the other week when i was flogging it i missed 3rd and then crunch, could not select any gear while the engien was running, you could select gear with engien off then start it with clutch pedal full down but the car would be creepign forward as iff it wasnt ingaing proply and have a metal on metal noise, anyway put new clutch, pressure plate in with trust bearing and slave and master, can select gear now, when pedal is 85-90 perfect pressed, as soon as you fully press it it doesnt selct proply and this metal on metal noise comes on
    any help guys?
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    Default Re: 4agze Clutch problem
    Have you checked the clutch fork because it might be bending. I had the same problem a few weeks ago, except i installed a new master cylinder which did nothing, then played around with the slave and the clutch fork just snapped off.
    Check that out
    I have been pruned by old man river!!!!!
    Junior Member Grease Monkey 3BarSuperstar's Avatar
    Nov 2007
    Maybe you are getting to much travel on the clutch fork? Check the adjustment at you pedal. Try backing it off a little.
    Tallahassee, FL USofA
    If the clutch fork was bending, there wouldn't be enough travel for disengagement.
    If the MC was changed to a larger diameter, or the slave smaller, there might be too much travel, but I doubt that Poggy's done that.
    Forum Sponsor Conversion King
    Dec 2006
    id hazard a guess at the wrong release bearing, some have a ring around the outside that can clash with the diaphram if pushed too far,
    was the pivot height set correctly?
    linden
    Linden - i suggested the same thing on the twincam forums.... although i dont know if Poogy has changed the release bearing since i sold the car to him, and it worked beautifully when i had the car.
    Is it possible that the release bearing could have come unseated on the fork?
    ...... butt scratcher?!
    The new bearign was the same as the one that came off
    I think you are going to need to pull off the gearbox to know for sure.
    That sux
    i'm just driving it now, once you get the hang of it its okay
    Here's a clutch manufacturers release problems list, with way more possibles then I could ever think of.
    http://www.lukclutch.com/support/dia...problems.phtml
  1. 4AGZE into a TA22
    By Valkyrie in forum Engine & Driveline Conversions
    Last Post: 20-10-2010, 05:57 PM
  2. 4agze Ignition Timing problem
    By Poggy in forum Tech and Conversions
    Last Post: 04-05-2007, 09:27 AM
  3. AE86 Clutch Help
    By Trizae in forum Tech and Conversions
    Last Post: 20-04-2006, 11:08 PM
