Results 1 to 9 of 9
Thread: Caldina 3SGTE wiring help
    Junior Member Grease Monkey Jaffa's Avatar
    Default Caldina 3SGTE wiring help
    Need some help please
    Engine 1997 Caldina 3SGTE (Auto) Conversion motor in a kit car
    The computer looks like it has 2 halfs, (Engine / Gearbox) I think we have sorted out the engine side of things
    Wired the whole engine loom in all sensors that relate to the motor are inplace ,..
    Sensor's that are not wired are things like ABS, Intercooler water, and also at the moment the Speed input sensor.
    None of the Auto gearbox wires are wired.
    Cranked motor over last night and it fired up straight away ran for like 3-4sec then dies ,.. seems to run smooth for this short time. I presume it is obviously looking for some type of input / feedback. Any ideas?
    I have not yet checked the error codes due to it being late and we called it a night, hope to get back to it later in the week.
    Also what sensor can i get away with leaving disconnected and what are compulsory needing to be wired so no performance is inhibited. Are any of the gearbox wires needing an input?
    Jamie
    Junior Member Backyard Mechanic YGT04A's Avatar
    Default Re: Caldina 3SGTE wiring help
    I know on my car if the intercooler water level is not plugged in it reduces power/boost but there is a way or tricking it when you go front mount
    http://www.users.on.net/~fivebob/Ima.../ST215W-1c.jpg
    http://www.users.on.net/~fivebob/Pages/pins.xml
    May help a little.
    Fivebob on Toyspeed.org.nz is the man to talk to.
    Junior Member Grease Monkey 3BarSuperstar's Avatar
    Nov 2007
    Does the fuel pump stop before the engine? I't might be priming on crank then stopping when you let go of the key. Circuit opening relay wired correctly if it has it that is?
    [QUOTEI know on my car if the intercooler water level is not plugged in it reduces power/boost but there is a way or tricking it when you go front mount][/QUOTE]
    Jono thanks mate that's teh sort of stuff i need to know ,.. i look into this some more and it just seem a simple case of jumpering the pins.
    May help a little.
    Thanks for the links, much appreciated seems that fivebob has done some heavy research into them. Notice that he has translated a russian diagram ( i think) and still has a fair bit missing, Will have to get on Toyspeed and have a good look round
    Got the running part sorted now, yep seems I had one wire slightly worng , it seems incredibaly doughy on the throttle after initial start up. Will start checking codes this weekend.
    I have so many more questions .
    As far as i can work out, is that the gearbox side of the computer is completley stand alone from the engine side , so in no way should it limit the engine performance if i leave this side of things with no inputs? can anybody confrim this or shed some more positive light.
    What about if the abs sensors are missing,
    incorrect speed input sensor as it is now running a manual box.
    will things like this limit performance, um anybody Help
    I should add wiring is definatley not my strong point.
    Jamie
    i'll carry the dina bible to work tomorrow and try to hook up a scanner
    That would be great ,.. no rush just when you get around to it ,.. thanks a million
    Nov 2007
    Anymore information on this front?
    Andrew
    Jan 2008
    The Netherlands
    We also did a 3s-gte caldina swap into an ST205 and now we cannot get the speedometer working, as the caldina operates the speedometer from the ABS computer? Did you use the caldina gearbox, if so do you have a caldina ABS wiring? Anyone has that available?
  1. SW20 3SGTE wiring question
    By Esteban in forum Engine & Driveline Conversions
    Last Post: 18-05-2007, 02:20 PM
  2. 3sgte distributor wiring
    By triptek in forum Tech and Conversions
    Last Post: 17-01-2007, 08:19 PM
  3. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 12:27 PM
  4. help, wiring an afc up to a gen1 3sgte
    By -=DV=- in forum Tech and Conversions
    Last Post: 20-05-2006, 10:52 PM
