Results 16 to 20 of 20
Thread: bodyroll in hilux
    Domestic Godess, NOT Domestic Engineer clubagreenie's Avatar
    Default Re: bodyroll in hilux
    www.tuck.com.au
    They should be able to sort it out for you. In sydney but internet ordering FTW.
    Friends
    Junior Member Backyard Mechanic DLA11D's Avatar
    Seeing your are in Vic i suggest DW Customs.
    1992 Toyota Hilux Extracab
    2JZGTE - TO4Z powered.
    1968 Toyota Stout Lite
    Work in progress
    is a semi-motivated Domestic Engineer 1JZ~lux's Avatar
    What generation is your Hilux? Toyota softened the suspension for the 4th and 5th generations (97/98 onwards). My 94 2WD single cab only gets body roll if the shocks are worn out. You could try King Springs Supa Lows with a Whiteline rear swaybar, but start with new shocks and poly-urethane bushes. If you put H/D torsion bars in the front as I have you will need a kidney belt. Even the smallest bump in the road will jolt you. There are a few coil-over conversions getting done around the place now, so that may be an option too.
    Petrol is for washing parts, alcohol's for drinking but NITRO IS FOR RACING!
    My pictures, Returning some time in the distant future.
    RN85 Hilux + 1JZ-GTE = 298.0HP @ 14PSI -- 60' 1.956 ET 13.775 MPH 99.49
    Project Korruption - Stage 1: The Resto. KE35 Corolla Hardtop daily driver
    02 model mate so gen 5? Thankyou for all the input have now got some good ideas to tinker with
    '02 would be gen 4. Gen 3 is '89 to '96/'97. Gen 4 is '96/97 to '05. Gen 5 is the current incarnation. Memory's faded a bit on the subject but I think this is pretty close to right.
  1. Hilux - BA Rotors - Nissan GT Calipers
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 20-02-2008, 07:27 PM
  2. Hilux Tow Bars and Wheels
    By Son of Toyoda in forum Tech and Conversions
    Last Post: 26-06-2007, 06:09 AM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 12:41 PM
  4. Alloy Trays on Hilux/ Cruiser/ Hilux 4 door
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 02-03-2006, 06:54 PM
