Results 1 to 11 of 11
Thread: What is the oil flow direction in the oil filter?
    Default What is the oil flow direction in the oil filter?
    Hey guys,
    Iam hooking up a oil cooler in one my Sprinters.
    My question is: Which way does the oil flow through the oil filter? ie. Does the oil go INTO the filter through the middle hole or is that the exit (back to the engine) hole?
    Why i ask, is that iam thinking of mounting the oil cooler SIDE ON, and i dont want the oil working against gravity, ie Pushing up the cooler......
    Any words of advice?
    thanks
    J Riftin
    Apr 2007
    Default Re: What is the oil flow direction in the oil filter?
    The oil flows through the outside first ( the small holes ) & back out through the centre hole, That way there is more surface area on the outside of the filter element to filter the oil & wont clog up as quickly either ...
    Forum Sponsor Conversion King
    Dec 2006
    Quote Originally Posted by JoJo
    if your putting the cooler on its side then make sure you have the outlet at the top, (so not the way you want to run it)
    dont worry about gravity as it wont affect shit, the main thing you want to aviod is airlocks.
    there have been countless times ive mentioned to a customer to change the way (somebody else) mounted the cooler (on a $200k+ racecar) and it wasn't until the 3rd set of bottom end bearings shat themselves that it was rectified and guess what its just done a full season with no problems.
    other than that lexsmaz is correct with the flow and just make sure you run decent qualiy fittings and hoses.
    linden
    Sorry, can you explain what you mean.....
    Are you saying it's bad to mount it side on?
    thanks mate
    J Riftin
    Iam using New DASH 10 Speedflow hose and fittings...
    Penrith BC
    no, side on is FINE, just mount the OUTLET of the cooler at the TOP
    ../delete/ban
    tech moderator
    Penrith BC
    and -10 isnt very big dude
    id prefer -12 for a cooler loop
    ../delete/ban
    tech moderator
    Quote Originally Posted by ed_jza80
    By outlet, you mean flowing back to engine??????
    can you be more specific? it's not clear what your saying.....
    by OUTLET he means where the oil comes OUT of the cooler, this is so it fills up with oil and pushes any air out the top, as opposed to the oil going in the top and the air trying to go up too.
    im not sure it can be much clearer!
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    thanks mate
    no prob, roughly where are you planning on putting it?
    i wasn;t sure on the direction, so i had a look and i agree it goes IN the fliter via the holes on the outside, and OUT of the filter via the big screw hole on the inside.
    have a look at this
    http://www.fluent.com/solutions/automotive/ex214.pdf
    gluck!
    www.vicdrift.com
  1. Direction of flow for 1JZ Fuel Rail
    By yann in forum Tech and Conversions
    Last Post: 23-09-2006, 12:14 PM
  2. Intercooler flow direction
    By Biggo in forum Tech and Conversions
    Last Post: 10-01-2006, 08:53 PM
  3. Full flow Oil filter relocation line thickness
    Last Post: 02-01-2006, 05:21 PM
