Results 16 to 21 of 21
Thread: HELP! I think my 1G just died...
    Default Re: HELP! I think my 1G just died...
    Well, if it helps, I got a death rattle one day too.
    It turned out, the fly wheel bolts had come loose, and the flywheel was pivoting on the back of the crank. Pull off, clean up and bolt back on again, problem fixed.
    However, I think I was lucky.
    When my engine went bye byes, I didn't even know it. It didnt' make any different noises or anything.
    So my experience says, when a 1g actually DOES make noise and start to complain, it's WELL gone. It's not just going to take some superglue to fix it.
    Facebook | LinkedIn
    West Australia
    True, 1G's are tough engines .... if there is a obvious noise coming outta the head/block then u know its day has ended
    30DET... The only way. Carport Converter Kyosho's Avatar
    I was thinking when I started reading, sounds like a clutch/flywheel issue.
    Would also explain why the damn car won't move.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    Aug 2006
    guys, thanks very much for ur replies, its given me a heap of different things i can check before jumping into getting a new motor (if needed, i know everyone says to take it to a mechanic etc but i just cant afford to do it..) so all the feedback is awesome. from the last few posts it is starting to confirm my previous thoughts about it having had its day.since i need to take the box off to get the motor out, will check out clutch/flywheel for destruction or loose shit. MAYBE its that and just shitting leads (one can hope) but at least i know which way im headed.
    many thanks guys, have a good christmas!!
    Worlds Fastest 1G Backyard Mechanic
    Leads don't make your engine rattle. Consensus is flywheel or bottom end, flywheel is way more work to check first, drop the oil in a clean container and look for shinny shit in it, if yes, bearinsg are gone, if no, then move onto box, I'm sure you can afford $20 worth of oil.
    6BOOST
    has anyone considered it may have spat a shim? they make some nice noises when they do that... and have this desire to not do shit, has something to do with a valve or two being constantly shut i guess...
    Quote Originally Posted by GBC_069
    well i came across a random issue today in my 3s-gte.
    its got as of last week, new adaptronic, new turbo, new fucking everything then
    today on the way to work, something goes POOF , shoots shit outta the zorst, and now no boost ??? GO FIGURE ! i am mighty annoyed and am just hoping its not a stuffed turbo !
    ceramic turbine?
    you will find it in your cat/muffler
    pull the dump pipe off and check, there will be no exhaust wheel.
    been there, done that a couple of times now
  1. 20v died
    By deltathing in forum Tech and Conversions
    Last Post: 05-04-2006, 05:11 PM
