Results 1 to 15 of 19
Thread: Cast Iron Manifold
    johor
    Default Cast Iron Manifold
    Guy's
    I do know Cast Iron manifold advantage is on its strength. But i would like to know this. Is it very tough or difficult to unweld flange from cast iron manifold?
    Default Re: Cast Iron Manifold
    Cutting a flange off any manifold is easy, but welding with Cast iron can be difficult, so welding a new flange on may prove problematic.
    Jordan
    Cast Iron? you mean steal? iron rusts like crazy, wouldnt last a day.
    Steal heads weld up perfectly, always better than alloy.
    i got a mild steel turbo flange i made brazed to a cut cast 4age manifold. very strong. braze mild steel to cast, do not weld.
    The problem with cast stuff is the metal is full of impurity making the fusion of another plate or whatever else more difficult than if you were working with a good pure material. It is possible as mentioned above though.
    Have you thought about just having an adapter plate made up that bolts to the cast manifold and the new turbo or whatever it is that you plan on attaching.
    Quote Originally Posted by Screamn_Sleeka
    I think you'll find all standard turbo and most non-turbo exhaust manifolds are made out of cast Iron
    Jordan
    I have never seen a Steel head... can you give me an example please?? I have only ever heard of Cast Iron, aluminium alloy, and magnesium alloy.
    I just dont think you have a clue as to the material properties of Cast Iron, as there is actually more carbon in it than steel, by about 10 times the percentage, which makes it more corrosion resistant, hence why it is not often painted!!
    If we are talking heads. No, they are cast iron as O-man has pointed out. And cast iron heads are a bitch to weld. Likewise with blocks. May i ask, have you actually ever tried?
    i'm sorry, but i wouldn;t believe anything from someone who spells it "steal" instead of "steel"
    there is such a beast as cast steel, but you won;t find it on a car engine very often.
    cast iron is used because it is cheap and reliable, and thats about it.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    The only material out there that rusts, is iron.
    Rust is iron oxide.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    johor
    Quote Originally Posted by LeeRoy
    actually its not the turbo flange i wanted to cut off but the header flange
    call into your local autoparts store, ask them to order you a head flange from lukey/walker to suit your engine. they sell head flanges to suit most popular engines seperate to the extractors they make.
    it can be done, but you are better off starting with a steel flange, and getting it laser or water cut or whatever it is they do these days
    to weld cast iron there are a few methods.. the main issue is that it has like 4-5% carbon, and when you mix with low carbon steel (0.2 or 0.3%?) you go thru a nasty area where you get lots of brittle phases..
    i have heard of people heating for a while with an oxy torch to burn out the carbon.. or, welding using high chromium and nickel (ie, stainless steel rods) to trap the carbon....
    but if you are making the rest of the manifold anyway, it is probably much better in the long run to start with a fresh flange...
    chances are you can buy one off the shelf somewhere anyway.
    johor
    alright. Tks for everyone inputs.
    Sorry guys, i read HEAD instead of MANIFOLD, i r retard.
    Quote Originally Posted by Kyosho
    Rust is iron oxide.
    All metals rust, expcet Gold, Platinum and Palladium, the majority of rust on iron or steals is Iron oxide, yes thanks for that.
  1. Which 4age intake manifold for turbo?
    Last Post: 17-10-2007, 07:34 PM
  2. Pistons - Cast vs Forged vs Hypereutectic
    Last Post: 21-11-2006, 02:04 PM
