Results 1 to 9 of 9
Thread: 1JZ Throttle Body Vac Line
    Default 1JZ Throttle Body Vac Line
    Can anyone help me with where the vacum line fitting that is before the butterfly on the throttle body goes to? engine is a 1jz_gte from a zz30 soarer
    Default Re: 1JZ Throttle Body Vac Line
    there a few there man posting a pic asking might be easier.
    if you post a pic i can walk outside and look
    here is a pic of the offending vac line...anyone got a full vacum system diagram i think i need to verify a few others
    ill have a look when i get home tonight if not else beats me to it
    drunken escapades Conversion King fatboy13's Avatar
    ill have a look at lunch for you if you want...
    watching a bunch of supraforums members try to debate something technical is like watching a bunch of retards try to fuck a doorknob...
    It shouldn't be a vac line as it isn't post throttle body..
    I believe that port is for the Power Steering idle up.
    There should be a hose that runs from that port to the PS pressure bypass valve in the high pressure PS line, the PS pressure bypass valve opens to allow some air to bypass the throttle body (the other connection of the PS pressure bypass valve goes to the other side of the throttle body).
    This makes the engine not stall when you wack full lock on at idle, or doing a U turn
    If you aren't using it I'd block it off as it will be a boost leak
    Thanks wilbo i will block it off seeing as the power steer lines i had made up for the VL done have this function
    My idle up vac line isn't connected in my car. It seems to work fine. I've done full lock turns and been driving it for a few months without issue. I've got a bolt plugging the hose. It was making a horrible whistle when it was left open and the car idled like a maniac (read: high).
    Simon.
    1991 Toyota Cressida (JZX83).
    i can confirm this goes to the idle up valve on the powersteering, just checked it then
  1. Throttle body change, vacuum leak?
    Last Post: 25-07-2006, 06:15 AM
