Results 16 to 18 of 18
Thread: Alloy Pulleys
    Default Re: Alloy Pulleys
    Quote Originally Posted by Cuts
    one of the problems is as there is a rubber ring around the inner section thats keyd to the crank, and the outer section with your timing marks on it, as they get old as has been said the rubber gets hard and perishes, and in some cases lets go alltogther. When they move it effectivly puts your timing out (if you redo it) because its might say 10 deg afte tdc but when its actually 7 after tdc (because the rings have moved in relation to each other.
    that onyl affects you if you retime using the crap new marker..
    the ignition timing os driven off the cam, which is driven by the cam belt, driven by the toothed sprocket, seperate to the crank pulley...
    if it lets go, a bigger worry is that the alternator and water pump don7t spin so fast..... or.. more to the point, makes noises like a falcon and smells like burnouts
    this mob makes them for 4age's, and 4agze's too, among other things
    http://www.nonstoptuning.com/index.htm
    i have 1 of their underdrive crank pulleys on my starlet motor, bought it from them direct, no worries
    Tasmania
    yes the ecu read off the crank angle sensor, but what do use to make sure the dizzy is on tdc, the crank pulley. So you might think its on 10d tdc, and the ecu assumes its on 10 d tdc, but it could actually be many degrees either way.
    either way its not good, so a new stock one or an aftermarket alloy one is the go 4 sure.
    additional fensport turn/manufacture/sell parts for a lot of performance models, blown 4ag included, www.fensport.co.uk. They are generous with their prices but their shit is pure quality.
    1973 TA22
  1. W5X Speedo Drive Comparision (Steel plate vs Alloy plate)
    Last Post: 12-08-2011, 07:58 PM
  2. 4age under drive pulleys
    By mc68 in forum Tech and Conversions
    Last Post: 29-06-2006, 10:23 AM
