Results 1 to 9 of 9
Thread: Diff crownwheel bolts
    vic
    Default Diff crownwheel bolts
    I am looking for some new bolts for my diff crownwheel. They are M10x1.25 20mm long The centre is off an old Crown but I wonder if anyone knows if later model cars use the same bolts and if you can buy some originals. If anyone has any part numbers that would be great.
    tasmania
    Default Re: Diff crownwheel bolts
    just go to a good toolstore and they'd either have them or could tell you where to get them.
    make sure you ask for high tensile bolts.
    beer me!
    There is a place up here in North Parramatta that sells just bolts and nuts called the nut house. If you can find a place like that down near you then they would have exactly what you need.
    Maybe ring toyota, although a bolt shop will be cheaper guaranteed.
    vic
    Thanks guys. I have been to a few Bolt shops but they did not have the style of bolt required. They offered me socket head cap screws which I rather not use.
    Toyota need part numbers of models to supply bolts. I cannot just show them a sample.
    Smile Re: Diff crownwheel bolts
    Hi crownman here,, i will find part numbers for you tomorrow. Regards Steve 0412 711 481.
    Quote Originally Posted by gemtoy
    Blackwoods are good suppliers of bolts. Socket/cap head bolts often come in a 12.9 tensile strength.
    V8 motavation. Grease Monkey 289hilux's Avatar
    Oct 2007
    Thanks[/quote]
    Surely ARP would make something try VPW or a good speed shop.
    Looks like the flywheel bolts for a 4AGE are the same size and pitch.
    Maybe some other types will be a match.
    Try here.
    http://www.arp-bolts.com/Catalog/Cat...atalog062.html
    Injected 5.0L FORD power in HILUX is the only way forward!
    See my ride here: http://www.toymods.org.au/forums/sho...246#post601246
    The bolts are Toyota part no. 90101-10237 need 8 and new lock washers part no. 41222-30011 need 8. Regards crownman 0412 711 481. Crown parts 1964 to 1984
    vic
    Quote Originally Posted by crownman
    + rep for you . I rang Toyota and they can order the bolts Thanks for getting the part numbers.
    I also sent you a pm
  1. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  2. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 12:41 PM
