The CAS is on the left of your pic, the black plug with the wires coming out the back of it.
It creates a signal from the toothed trigger disc that is pressed onto the rear of the timing belt crank sprocket.
Are all the timing marks on the crank and cams still lined up after having the belt off?
The other sensors for the ignition are up on the intake side of the head near the injectors, two plugs for the cam sensors.
it was hard up against the bottom (left) of the groove
