Results 1 to 14 of 14
Thread: R154 Twin Plate...
    Default R154 Twin Plate...
    Okay, so ive been told i need to use a input shaft to line up my twin plate, but is there another way to do it which isnt impossible or is it just the one
    I dont have another spline and i reaallllly wanna do it now. haha
    Is there an alignment tool with splines?
    Anyone got a spare spline? lol
    Cheer,
    Jase
    JZA023
    Forum Sponsor Conversion King
    Default Re: R154 Twin Plate...
    W58 spline is the same if you can find a blown 1.
    i line them up by eye when i have to, it aint that hard.
    linden
    Balloon Slayer Backyard Mechanic jimmmayyy's Avatar
    Apr 2007
    you can buy a little plastic tool for just that purpose, it's called a clutch alignment tool funnily enough. would'nt be more than 5-10 bucks.
    Yeh but its a twin plate, so you need to aling the splines aswell as the clutch plates...
    Ive got a w58 but its a good box and i dont particularly want to pull it apart...
    So r154 and w58 are same, what about w50 and 55?
    Jase
    JZA023
    your mums an Carport Converter pato's Avatar
    wait. the post said about r154 tho
    with the r154 it has little viewing windows. so u can slide the pressure and clutch plates on, and bolt them together later.
    but the w58 doesnt.
    therefore a shaft sorta thing is needed.
    a mate of mine who owns a machining shop just made one based off the old clutch plate and spigot bearing. may be the easiest option
    Quote Originally Posted by RAd28
    I certainly don't need to stick my hand in a blender to know it'll cut my fingers off, and i don't need to weave in and out of traffic at 120 to know it's fucking stupid.
    blown 58, cut off input shaft = win.
    i have a box lying around that i may cut 1 off, how urgent?
    linden
    Junior Member 1st year Apprentice Jzxbenno's Avatar
    Nov 2007
    Hello
    I just put ORC twin plate on the back of my 1j for r154 i bought a special little spline thing thats exactly the same as the r154 spline from adelaide all clutch and brake (08) 8277 8122 cost me $12 has part number toyota11 on it
    Ben
    Thanks dude, gotta spread the rep love before i can hit you again
    Jase
    JZA023
    Smokey... it's possible to do it by hand. use a bit of thick wire/allan key type thing, and get it centred by eye.
    It helps if you have a gbox specialist a few doors down
    south austraila
    Top loader, corola, T50, W57/8....
    Project: '82, GA61 XX
    Oh k.
    Ill look into these than!
    Jase
    JZA023
    Apr 2007
    Thats exactly the tools i was referring to, cheers GA
    User Conversion King
    NWA
    you can half tighten the pressure plate bolts and put the gearbox on the engine. once its lined up, tighten PP bolts.
    hello
    Cheers guys, i got a w58 input shaft and used it to line up the clutch plates. Than slid the box on tonight. I ordered new flywheel bolts today, but put the motor and box together to try and dummy fit it into the car so i could massage the tunnel away...
    But dammit, i couldnt get it into the car in my bloody low garage! Not unless i remove all the un-needed p/steer and a/c shit...
    Jase
    JZA023
  1. HKS twin plate clutch for JZA80
    By Draven in forum Tech and Conversions
    Last Post: 15-04-2006, 07:44 AM
  2. twin plate clutch over a single plate 6 puck carbon version
    By devil_rolla in forum Tech and Conversions
    Last Post: 02-03-2006, 10:20 AM
