Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: Water to Air Intercooler on 4AGZE
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Default Water to Air Intercooler on 4AGZE
    Just curious to know if anyone has successfully added a water to air intercooler to replace the top mount intercooler on the 4AGZE?
    I can get my hands on a Subaru heat exchanger fairly easily, the ST205 is much harder to come accross. I think by looking at it the Subaru item could be modified to work.
    If anyone has done so what sort of benefit will it give?
    Default Re: Water to Air Intercooler on 4AGZE
    Yes. Do a search. Was it Poojou who did it?
    New Zealand
    i have done it in an aw11
    VAST improvment
    much much better than a front mount in a FWD too
    please, no more PMs!
    Junior Member Conversion King deviant's Avatar
    wa
    My AW11 MR2 has got a W2A intercooler.
    Vast improvement over the stock top mount. I believe intake temps get as high as 120c with the top mount, a W2A will see you down to just above ambient temperature.
    If your in a front engined application you can put the intercooler a lot closer to the engine to reduce hose lengths.
    Lots of AW11 owners fit them.
    Quote Originally Posted by S2K
    Would a VTEC limiter be a helpful device?
    May 2006
    Nice anyone got any pics?
    Warwick, ill pick your brains about it next time i call to annoy you
    New Zealand
    see, this is why i hate forum names... i got no idea who you are
    some pics here
    http://s3.photobucket.com/albums/y82/Mr-Revhead/aw11/
    May 2006
    Quote Originally Posted by Mr Revhead
    some pics here
    LOL, well if I said my Blacktop 20V gasket kit, TRD head gasket and 4AGZE pistons arrived from you today will that ring any bells?
    Chiba
    Where can I source a decent aftermarket w2a intercooler as a topmount replacement?
    Is it feasable to weld panels to the stock 4AGZE intercooler to box it in and run water through it instead of air?
    May 2006
    Quote Originally Posted by TERRA Operative
    Aftermarket systems are expensive but of course probably easier to plumb in a custom setup. PWR do a range of liquid to air intercooler kits. http://www.pwr.com.au/images/intercoolers/4x6_kit.jpg
    I believe these start at over $1000.
    Modifyiing a stock air to air intercooler as you say can be done if your handy enough. Something like an RX7 intercooler would probably be a better candidate than the 4AGZE one. You need to find something with metal end tanks to be able to enclose the core.
    The Subaru heat exchanger is probably the most common to find and obviously the cheapest method. The biggest problem is the inlet from the turbo that tucks in under the body of the unit. In my case I am looking at cutting this off and welding my own intake to suit. The other system would be from the ST205 GT4 but these are extremely rare and demand a much higher price. Although they would proabably fit better without modification as the Subaru does their not really worth chasing in most cases.
    have done the subi liberty w2a in a gze sierra.
    worked a treat, much better than the standard interwarmer in low range
    May 2006
    Forgot about you Drew. Have to see this Zook one day
    i've had the st205 w2a i/c in the feral's 4agte for years, it has worked very well with my flogging it around and across Oz! at first i had a a/c condensor as my heat exchanger, but then modified a vn crummydore radiator, MUCH better. the bigger the HE the better in a w2a set-up IMO.
    not best pic, but you get the idea of the size of it.
    i've recently pulled the st205 core from the feral am i am going to put it on the lil feral's TC. i've bought another w2a core for the feral.
    gunmetal another aw11 owner has a st205 core mounted very neatly ontop of the engine in a simular set-up to the 3sgte gt4. there be pics of it in the aw11 thread somewhere.
    just found these in one of my aw11 folders, stock a2a unit turned into a w2a. a few fellow owners in the states have done this and rekon it is heaps better than stock a2a.
    i do have more pics of different ones here somewhere, but beleive me you dont want to go through all my aw11 folders/pics, will take all night!
    Junior Member
    Nov 2007
    Christchurch
    I highly recommend fitting a w2a intercooler. I've fitted the Subaru EJ20's w2a i/c, i/c pump and front heat exchanger to my AW11, and I consider it to be one the best mods I've ever done to it.
    On the race track I'd see intake temps around 180F with the old a2a intercooler (I'd positioned it above the gearbox and had fans above it to suck air through it). With the w2a, my intake temp won't even register on the guage which starts at 100F (and that's even after 8 laps of a 3.33km circuit).
    And I picked up the whole Subaru setup for only $50 off Trademe.
    The whole thing was very simple to install.
    johor
    hm... i've been toying about this idea for long but worry about the keeping the temp consistancy. FYI, im having ae111 turbo with fmic now. I would like to know
    1. Will w2a intercooler give me lower air temp compare to my FMIC at night? Coz i do most of the running at night. It seems like all the feedback was frm mr2 owner.
    2. How big does the w2a intercooler neede only to sufficient x rated horsepower? Woth 200whp, does Subaru w2a i/c sufficient enough?
  1. water injection pre turbo
    By project_x in forum Tech and Conversions
    Last Post: 28-03-2008, 07:41 AM
  2. Water injection vs Intercooler
    By Gibbon in forum Tech and Conversions
    Last Post: 21-10-2006, 04:57 PM
  3. Cooling Systems - Overheating Problems.
  4. 4AGZE Intercooler and exhaust suggestions?
    By DavisJD in forum Tech and Conversions
    Last Post: 07-02-2006, 05:20 PM
