Some do, some don't.Originally Posted by blah_00
No probs. Click my rep thing if you found it helpfull. I want an avitar.Originally Posted by blah_00
Well this is what I'd like to know. Would extractors help at all? I don't know enough specificaly about the 5S-FE, and haven't modded one so can't say for sure. My GUESS would be that you'd actualy lose power, but it's just an educated guess, not fact.Originally Posted by blah_00
As for lumpier cams, yes, it means they would have higher lift and duration. Although as said, the whole head is designed for low revs, so even if you overcome the lift and duration, then you have valve sized (which can be changed to an extent), and port shape and angle (which are impossible to change), and if you do put lumpy cams in, it might hit the piston and cause exploded engine.
I know the SR20DET engine is a CLOSE angle head. But close angle doesn't = bad, it just makes it harder to make a sports engine out of one due to the port angle, and valve size. A turbocharged engine isn't going to have as much trouble with flow in the head, as it's having air forced into it, rather than having to suck air in. So if you're talking about Turbo SOHC Lancer and Civics, then yeah, that'd be why. Once you start talking about turbos though, it comes down to boost and all gets a bit silly what with tuning and how long the engine will last, etc etc.Originally Posted by blah_00
Anyway, the real issue is, to get the 5S-FE to be any good at all would cost FAR more than just dropping a 3S-GE in there, or even a 3S-GTE. and in the end, the 5S-FE isn't going to perform as well.
