Results 1 to 13 of 13
Thread: how do I remove these?
    Default how do I remove these?
    How do I remove the knob's on the fan control on my RA23 without damaging them do I need a special tool? any help would be appreciated
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Melbourne Victoria
    Default Re: how do I remove these?
    you can either pull them off or there might be a small screw under them ,so you will need a phillips screw driver
    Junior Member Backyard Mechanic Supra-Jim's Avatar
    I am pretty sure they are just a press fit over the stalk. You should be able to pull them and they will slide off. I have had other cars that worked this way. Though someone who's pulled apart a Celica should really confirm it.
    hope this helps.
    They call them fingers.... but i've never seen them fing!!!!
    Just pull on them.
    yeah the previous car i pulled on them and they never went back on, well not with the help of super glue anyways. Didnt think to look for scew's underneath, will have a look now
    12.4 @ 110mph
    NOOOOOOOOOOOOOOOOOO
    DO NOT pull on them.. without checking for the small screw underneath.....
    otherwise they be fucked real bad and you'll need new ones...
    ALL the ra23 ones I've ever seen (and I've seen too many to want to remember) were all Pull type.
    Facebook | LinkedIn
    No Screws, just an annoying little clip...
    Just pull them off, they can be a real bitch sometimes, but make sure you don't loos the little clip that sits inside of them otherwise, even with the use of superglue, they wont go back on...
    ([][][]II--LT--II[][][])
    They were definately the push on type on my '23, you have to pull f*****n hard sometimes though
    Another vote from me for them not having any screws
    Definitely no screws... they might be tight, so add some Inox if they are.
    ...... butt scratcher?!
    Junior Member Backyard Mechanic lojik's Avatar
    I may be wrong, but...
    They look like the ones on my ma61, the metal you see running around them is part of a spring and ball arrangement that holds them on.
    They just pulled off, but I imagine if the ball became lost they wouldn't go back on too easy.
    thanks guys, all sorted
    12.4 @ 110mph
  1. Idiots guide to a 1jz conversion into a MA70 bodied supra.
    By Xistant in forum Engine & Driveline Conversions
    Last Post: 12-07-2019, 05:11 PM
  2. Replies: 9
    Last Post: 12-04-2008, 05:59 PM
  3. How to remove car door lock - lost keys.
    Last Post: 07-07-2007, 09:46 PM
  4. How to remove Corolla engine ?
    By corolla16 in forum Tech and Conversions
    Last Post: 27-06-2006, 12:49 AM
