every engine will require a slightly different tune unless its conservative. but you may get away with the maps that are in his (probly best to check it on a dyno straight after the upload)
not sure on the cable Q
linden
Hey peeps, firstly i have an ae82 with a ae101 gze, my throttle cable has broke, are the ae92sx and ae82 bigport cables the same?
Also about to purchase a mircotech, i have a mate with same seriers gze as mine, same mods exactly can i copy his flash and load it to mine?
Cheers James.
linden
Originally Posted by WHITCHY
yeh use his to get yours to a dyno it always pays to get it retuned for what ever reason when you change stuff.
with the cables im not shaw but were the throttle body is on the big port manifold is a little bit further away from the gze so it might fit.
Yeah a twinky throttle should fit.
Just go to the wreckers and take a whole bunch of different ones![]()
...... butt scratcher?!
All engines are different. The standard gze tune that comes with the microtech will run it not sure on how much boost though.
All ways get it to a dyno tune. You may very well make more power than your mate.
