Results 1 to 4 of 4
Thread: JZA80 cam breather 90 degree pipe thingy
    Default JZA80 cam breather 90 degree pipe thingy
    Hey all,
    Linden is currently building me a very shiny catch can, but to hook it up properly I'm looking for a pipe with a 90 degree bend in it to go into the passenger side cam cover.
    This cover has a PCV valve type thing that is usually just hooked straight to the plenum, which unfortunately means that without a 90 degree bend in that fitting, the pipe to the catch can will be crimped. Any suggestions on what might fit in this hole?
    User Conversion King
    NWA
    Default Re: JZA80 cam breather 90 degree pipe thingy
    i had to do something ghetto with mine to get a vacuum supply. my GTE manifold had no vacuum port for the brake booster. anyway thats another story.
    im sure pirtek would have a bling-brass 90deg bend of the right diameter for $5
    alternatively you could try a 1JZ PCV outlet tube as they come with a 90deg bend from factory.
    it can be seen halfway back on the passenger side in this random pic
    http://img322.imageshack.us/img322/5039/img02477ht.jpg
    hello
    AWESOME
    I thought the 1jz had the bend, but wanted to make sure. that's perfect, thanks Brett. Would rep you again, but can't
    I was going to say get a speedflow fitting but i realised that you wanted just a pipe. Seems as though the one above is the right thing for the job too. If it isnt you could always scavenge through the hose bin at supercheap.
  1. Replies: 9
    Last Post: 12-04-2008, 05:59 PM
