Results 16 to 17 of 17
Thread: Pics; Checking fuel tank for leaks. Is it ok to run water through it?
    Negative Reputation Domestic Engineer Howieau's Avatar
    Default Re: Pics; Checking fuel tank for leaks. Is it ok to run water through it?
    Thanks for the inputs. The soapy water trick went down a treat haha, it is leaking. Dang
    Is there a home remedy to fixing or must it be taken to a radiator shop. You can see in the pics a silver strip welded/soldered on it, it seems its not the first leak its had from that spot.
    I also found a nice chunk of weld IN the tank when I first opened it up, a bit bigger than a 10 cent coin lol. Crazy
    "There is a better way to do it, find it" -Thomas Edison
    Junior Member Backyard Mechanic TC1600's Avatar
    Feb 2007
    At work we have a big copper soldering iron (that you use an oxy torch to heat), takes a while but you just solder it up.
  1. Fuel cooler / fuel temp
    By Pearce in forum Tech and Conversions
    Last Post: 12-05-2007, 07:55 PM
  2. rising rate fuel regulator-tuning-basics?
    By petespipes in forum Tech and Conversions
    Last Post: 30-01-2007, 09:29 PM
  3. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  4. Cooling Systems - Overheating Problems.
