Results 1 to 15 of 27
Thread: high compression 7M
    Apr 2007
    Default high compression 7M
    Hey all,
    After getting my MZ20 soarer just a couple of weeks ago, a dodgy batch of fuel has screwed it and now has a slight rattle... time for a new bottom end.
    My question is has anyone here had any experience with using the GE bottom end for higher compression? With the GTE at 8.4 vs the GE at 9.1, there isn't really a great difference. I have done this before with an RB30, (7.8 vs 9.0), with really decent results, better off boost response etc. Is there really any possible major issues with a setup like this?, ie differences between blocks possibly?
    I'm not set either way as yet and nor have i gotten any prices yet, but i'm assuming that a GE bottom end would most likely be cheaper. Anyone know a good place where I could hopefully just source a short motor in SA?
    Would just like to hear anybody's thoughts/opinions/experiences with this. Would I be better off with a GTE bottom end?
    cheers, -jimmy
    Junior Member Backyard Mechanic haison's Avatar
    Default Re: high compression 7M
    From memory the GTE bottom end has oil squirters and the GE doesn't. You'd be better off getting the GE pistons into the turbo bottom end. Are you still going to be running a turbo? Cause it'd probable ping it's head off with out a decent ecu and very good fuel.
    1984 MA61 - http://www.toymods.net/forums/showthread.php?t=12340
    1972 RT81 - http://www.toymods.net/forums/showthread.php?t=24160
    RObErT_RaTh - I think it's fair to say we all love the bush
    Viper_Nipplex - If bush is this popular, just wait until the boxes are ready
    yeah, mate, 8.4 vs 9.1 is a fair jump. It ain't insignificant like you suggest.
    Facebook | LinkedIn
    30DET... The only way. Carport Converter Kyosho's Avatar
    I beleive you'll be fairly surprised at how cheaply you can pick up whole 7M-GTE.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    At Work I'm A Grease Monkey Hibba's Avatar
    Jin~Jah is running a GE bottem end in his GTE cressida. Runs perfectly fine. no pining. have ran up to about 12psi on it.
    Computer is the factory 7MGTE one with a HKS VPC.
    MX83 Grande
    DirtyWan Skyline GX
    there is no problem with 9:1 and boost.
    Numerous production engines these days are running over 9:1 and some even over 10:1 and boosted. As long as the ECU will cater for the needs.
    Apr 2007
    ahh ok oil squirters. i wasn't aware that GTE's had them.. thats a good enough reason to stick with that.
    strad i'm not suggesting its insignificant, just that there is much better fuels available now than there was back when they were made.
    yeah i know they aren't too expensive, but prices in SA are rather inflated over prices in the east. i had good results with a higher comp RB30, so i was just considering the same with this motor. being twincam and better chamber design than the RB30 with less of a difference between GE vs GTE, i'd have thought that it could be a worthwhile thing.
    S.A
    Are the pistons the same in the GE as the GTE
    Ie: does the GTE have forged pistons or a stronger designed piston to cope with boost ?
    Apr 2007
    as far as i know they are both cast... so besides the different height i think they may be the same. can anyone confirm or deny?
    Fuel qaulity and detonation resistance has actually gotten worse over the years.
    30psi: they are both cast. But the GTE pistons are dished on the top.
    MX83 Grande
    DirtyWan Skyline GX
    Quote Originally Posted by jimmmayyy
    There were 3 gen's of 7MGTE's
    Gen1: 6M Crank. No Squiters.
    Gen2: 6M Crank. Oil Squiters.
    Gen3: Double Counted Waited Crank. Oil Squiters.
    MX83 Grande
    DirtyWan Skyline GX
    I can think of a reason that this might go sour... the head gasket
    What are you doing to counter the infamous 7MBHG when you put more compression with boost there?? Also I would be seriously considering an aftermarket ECU with this (as suggested, fuels have gotten worse over the years, and with global worming ambients are up )
    We have 98 and 100 RON fuels available today, neither of which were available when the 7M was released, so I don't see how fuels have gotten worse over the years? Sure we had high octane mega-leaded fuel in the 70's but that's hardly relevant here.
    IMO high-compression turbo engines are an awesome idea but good engine management and a top-notch tune are a must.
    Sulpher content has gone up, as have other impurities. It negates the improved octane. Basically we are getting dirtier fuels these days.
  1. My high compression + boost concept
    Last Post: 18-06-2012, 09:40 PM
  2. question: Low CR vs. High CR for forced induction?
    By AndyTTR in forum Tech and Conversions
    Last Post: 24-11-2009, 05:11 PM
  3. very high comp... good engine or worn rings?
    By Vios-GT_07 in forum Tech and Conversions
    Last Post: 09-06-2007, 07:45 PM
  4. 7m and high boost
    By itchybum1 in forum Tech and Conversions
    Last Post: 23-03-2007, 01:11 PM
