got picks of the rest of it?
my mates clutch did this in his civic....turns out it may have not been a genuine Exedy (wasnt stamped) but other than that the friction material just fell off.....
exedy stock replacement about a year old (30000kms or less)
showed no signs of slipping before it spat the dummy.
I have been told its due to the pressure plate mulfunctioning, meaning i need a whole clutch kit.
what are your thoughts?
Wow thats nuts. Werent all those clutches sheldrake broke exedy ones too?
its not a fault of the clutch. what you have there is a misalignment of the input into the back of the crank ie its on an angle.
this causes flexing as the clutch spins which the workhrdens the material and snaps the disc.
it can be caused by numerous things ie:
flywheel not faced correctly
engine plate bent or missing
gbox not aligned on the dowels correctly
and a few other things but the above are the biggest contributors.
no a clutch supplier wont give you a refund because this is not a normal failure.
linden
Originally Posted by WHITCHY
i wasnt expecting a refund
flywheel was machined correctly, gearbox was on properly. Clutch supplier (different company) said exedy clutches are rubbish and likely to be fault of pressure plate.
as for the rest of it, i dont know haha, there were only a few shards left in the bellhousing. I presume the rest is on the road somewhere.
ive used alot of exedy clutches and never had a problem.
i have seen this on numerous occasions where a customer has changed the clutch himself and bought it down to me because "it wont select gears properly" .only to hear a crunching noise and after removal of the gbox ive seen this.
linden
Originally Posted by The Real Roadrunner
true
Ive done many a clutch in my day, this is the first to fail.
there was no sign of slipping or anything, just a sudden failure.
put it on ebay, sure some noob will buy it![]()
i vote misalignment as well.. if you are reverse loading the material on every revolution.. (perfect cyclic reverse bending test) and it is because of input shaft vs flywheel misalignment.. it should all break at once....
maybe there was something that caused the gearbox to not sit on dowels properly or? evan a mm out could cause it...
the gearbox was properly bolted up, i doubt it was that.
wonder what it was then?
if the flywhel and gearbox were "true", then the pressureplate couldn't do anything else but hold the friction plate flat on the true flywheel.... if it was slipping severely on one side, it could have failed first....
are there heat indications on any particular piece of shrapnel to indicate it failed first?
is still a fairly impressive failureand could have been manufacturing farkup.. but rare.
nah, if you look near the rivets that hold the outer plate on you can see that they have been worked to the point where it snapped.Originally Posted by oldcorollas
seen it on a few occasions, and yes even 1mm off on either side of the box can cause this over time, speaking of which how long had the clutch been in there?
linden
There you go Linden.Originally Posted by deaf_rattle
Nice job!
hmmm, back to school for me to learn how to read.
if its out by only a slight amount it would probly take that long to snap completely but it depends on how its driven.
linden
a couple of big metal shavings looked fine, clean etc. like a sudden failure.Originally Posted by oldcorollas
wouldnt i have noticed if the clutch was slipping?
