It'll do what you are planning but often on some cars it can be a damn fine line between increasing the boost a little and a little increase in boost response and starting to introduce boost creep.
Just do it in small steps and see how you go, test for boost creep too each step as it can be subtle and nothing to worry about or it can be bad and creep up several psi over the rpm range. You are effectively decreasing the working range of the actuator the further you space it (thus decreasing the amount the wategate flap can open in the turbo).
