Results 1 to 9 of 9
Thread: hey all - need big help with flywheel -> pres. plate bolts
    Turboholic Grease Monkey VeeP's Avatar
    Default hey all - need big help with flywheel -> pres. plate bolts
    hey all,
    in regards to 1JZ and R154 with standard pressure plate and factory flywheel
    tryin to get this manual conversion done but iv got the wrong bolts to mate the flywheel to the pressure plate (shithouse generic grade 8.8 ones when i need proper automotive ones i think). Ithink the right ones might be** part number 90119-08302 ** but i dont fuckin know if thats right?!?! and apparently the ones i need arent even in stock in any toyota dealer in oz? is anyone able to get me some REAAL soon or know where i can get em from? pplllzzzz!!
    cheers ppl
    '88 Soarer GT-L
    '90 Supra Aerotop
    Western Aus
    Default Re: hey all - need big help with flywheel -> pres. plate bolts
    apparently 4AGE ones are exactly the same?
    i know a few people on here know for sure though!
    have you tried giving JUST TOYOTA wreckers a ring. They should be able to sort something out. They are in Malaga and the guy to ask for is TAO. He has always been able to help me out with bits and pieces. They have a range of import motors and such and should have some bolts to suit.
    Cheers Dave
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    Western Aus
    here:
    http://www.toymods.net/forums/showthread.php?t=28046
    same as 4A.
    and malaga just toyota are fuckheads.
    90910-02103
    suits jzx90 with 1jzgte (I believe they had r154's?)
    they suit 1zz and 2zz as well as 1jzgte so toyota australia should have plenty in stock
    edit: btw the part number you quoted in your original post doesn't exist
    and also has anyone used 4age bolts in a 1j? The EPC has different part numbers for them
    I am the sun
    thanks but i already have flywheel bolts for a 1JZ (ARP items) -
    i want FLYWHEEL TO PRESSURE PLATE . . . . not flywheel to crank
    btw just for interest sake
    1jz flywheel bolts = BA XR6 flywheel bolts = 4AGE flywheel bolts!!!! truly!!
    but i digress, i desperately need flywheel to pressure plate bolts!!
    anychance i can take one i got and go to conventrys and get em matched up? i think i need grade 10.5 bolts
    '88 Soarer GT-L
    '90 Supra Aerotop
    Whoops sorry, should read more closely huh
    90119-08302
    That's the part number for a single bolt, it's a standard part, should cost SFA!
    I am the sun
    Western Aus
    Quote Originally Posted by VeeP
    oh my bad, complete brain fart!
    Nice..... Grease Monkey Rex_Kelway's Avatar
    Most Allen-Head cap screw are 10.5 grade. just use them, Rex suggests.
    You can really use any bolts, just make sure they are of a suitable grade.
    Rex Kelway Sucks - Fabrication thread
    Rex Kelway - ABN: 41 267 379 001
    Fabrication, Manifolds and CAMS spec Roll-cages in SA...
  1. 5M E to 5M GE/6M GE Conversion Guide
    By spiller in forum Engine & Driveline Conversions
    Last Post: 29-11-2011, 12:03 PM
  2. Quick Question: 1JZ and 2JZ flywheel bolts the same?
    Last Post: 01-05-2008, 01:42 PM
  3. manual flywheel bolted over flex plate??
    Last Post: 06-07-2006, 08:11 AM
  4. Flywheel Bolts 1JZ-GTE R154
    By rogue-vl in forum Tech and Conversions
    Last Post: 26-12-2005, 06:05 PM
